Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
Pull off the back cover of the laptop.
Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
Lift up the black tab next to the silver ribbon cable.
Pull lightly on the blue tabs until the silver cable is free.
Use a Phillips #00 screwdriver to remove the 5 marked screws.
Gently remove the battery.
Disconnect the WiFi antenna cables by gently pulling them in an upwards motion.
Using a Phillips #0 screwdriver, remove the screw holding the WiFi card down.
Pull the WiFi card out of the socket toward the fan housing.
Één andere persoon heeft deze handleiding voltooid.
