Ga door naar hoofdinhoud
Asus Q534U Wi-fi card Replacement
Wat je nodig hebt
  1. Asus Q534U Wi-fi card Replacement, Back Case Removal: stap 1, afbeelding 1 van 1
    • Make sure the device is turned off and unplugged from the charger.
    • Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
    • Pull off the back cover of the laptop.
    • A pry tool may be needed to pull off the back cover.
  2. Asus Q534U Wi-fi card Replacement: stap 2, afbeelding 1 van 2 Asus Q534U Wi-fi card Replacement: stap 2, afbeelding 2 van 2
    • Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
  3. Asus Q534U Wi-fi card Replacement: stap 3, afbeelding 1 van 2 Asus Q534U Wi-fi card Replacement: stap 3, afbeelding 2 van 2
    • Lift up the black tab next to the silver ribbon cable.
    • Pull lightly on the blue tabs until the silver cable is free.
  4. Asus Q534U Wi-fi card Replacement: stap 4, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the 5 marked screws.
    • Gently remove the battery.
    • Do not bend or puncture the laptop's lithium-polymer pattery.
  5. Asus Q534U Wi-fi card Replacement, Wi-Fi card: stap 5, afbeelding 1 van 1
    • Disconnect the WiFi antenna cables by gently pulling them in an upwards motion.
    • Needle nose pliers can be used as a detaching tool.
  6. Asus Q534U Wi-fi card Replacement: stap 6, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, remove the screw holding the WiFi card down.
    • Pull the WiFi card out of the socket toward the fan housing.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Eric Okoko
327 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S66-G6, Rockett Fall 2017 Lid van UMass Dartmouth, Team S66-G6, Rockett Fall 2017
UMASSD-ROCKETT-F17S66G6
3 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 18
Altijd: 3,003
