Ga door naar hoofdinhoud
Asus Q525U CPU Fan Replacement
Wat je nodig hebt
  1. Asus Q525U CPU Fan Replacement, Back Cover: stap 1, afbeelding 1 van 3 Asus Q525U CPU Fan Replacement, Back Cover: stap 1, afbeelding 2 van 3 Asus Q525U CPU Fan Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Begin by powering off the device and flipping the device over.
    • Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
    • Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
  2. Asus Q525U CPU Fan Replacement: stap 2, afbeelding 1 van 3 Asus Q525U CPU Fan Replacement: stap 2, afbeelding 2 van 3 Asus Q525U CPU Fan Replacement: stap 2, afbeelding 3 van 3
    • Use an opening pick to separate the back cover from the device.
    • For easiest removal, begin by prying at one of the front corners and sliding the tool under the cover in a counter-clockwise motion (to the left) toward the laptop hinge.
  3. Asus Q525U CPU Fan Replacement: stap 3, afbeelding 1 van 3 Asus Q525U CPU Fan Replacement: stap 3, afbeelding 2 van 3 Asus Q525U CPU Fan Replacement: stap 3, afbeelding 3 van 3
    • Once the cover has been separated from the device, carefully lift the back cover off the device (begin by lifting from the front of the cover first).
    • The back cover should be easily removable, allowing full access to all of the internal components.
  4. Asus Q525U CPU Fan Replacement, Battery: stap 4, afbeelding 1 van 3 Asus Q525U CPU Fan Replacement, Battery: stap 4, afbeelding 2 van 3 Asus Q525U CPU Fan Replacement, Battery: stap 4, afbeelding 3 van 3
    • The battery of the device is outlined in red.
    • Using a Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery in place.
  5. Asus Q525U CPU Fan Replacement: stap 5, afbeelding 1 van 2 Asus Q525U CPU Fan Replacement: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Halberd Spudger
    $2.99
    • Using the Halberd spudger, carefully lift the battery connector up to disconnect it from the motherboard.
  6. Asus Q525U CPU Fan Replacement: stap 6, afbeelding 1 van 1
    • Lift the battery out of the frame to remove.
  7. Asus Q525U CPU Fan Replacement, CPU Fan: stap 7, afbeelding 1 van 1
    • The CPU fan of this device is outlined in purple.
  8. Asus Q525U CPU Fan Replacement: stap 8, afbeelding 1 van 3 Asus Q525U CPU Fan Replacement: stap 8, afbeelding 2 van 3 Asus Q525U CPU Fan Replacement: stap 8, afbeelding 3 van 3
    • Using a Phillips #1 screwdriver, remove five screws from the fan and heatsink.
    • Remove one 3 mm Phillips #1 screw on the side of the CPU fan.
    • Remove four 2 mm Phillips #1 screws from the heatsink.
  9. Asus Q525U CPU Fan Replacement: stap 9, afbeelding 1 van 2 Asus Q525U CPU Fan Replacement: stap 9, afbeelding 2 van 2
    Halberd Spudger
    $2.99
    • Use the Halberd spudger to carefully disconnect the bundled slide connector that connects the CPU fan to the motherboard.
    • To disconnect it safely, use the pointed tip of a spudger to carefully push on each side of the connector.
  10. Asus Q525U CPU Fan Replacement: stap 10, afbeelding 1 van 3 Asus Q525U CPU Fan Replacement: stap 10, afbeelding 2 van 3 Asus Q525U CPU Fan Replacement: stap 10, afbeelding 3 van 3
    • Carefully remove the thicker black cord from the cord clips surrounding the fan.
    • Remove the fan from the device.
Conclusie
Stewart Crandall
571 Reputatie
5 handleidingen geschreven
Clemson, Team 2-5, Hunter Spring 2022 Lid van Clemson, Team 2-5, Hunter Spring 2022
CLEM-HUNTER-S22S2G5
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 9
Altijd: 473
