Ga door naar hoofdinhoud
Asus Q504UA-BHI5T13 Heat Sink Replacement
Wat je nodig hebt
  1. Asus Q504UA-BHI5T13 Heat Sink Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Ensure that the laptop is off so you do not shock yourself.
  2. Asus Q504UA-BHI5T13 Heat Sink Replacement: stap 2, afbeelding 1 van 1
    • Use the T5 Torx screwdriver to remove the ten 1mm screws located around the back cover.
  3. Asus Q504UA-BHI5T13 Heat Sink Replacement: stap 3, afbeelding 1 van 1
    • Remove the two rubber pads nearest to you using the metal spudger.
  4. Asus Q504UA-BHI5T13 Heat Sink Replacement: stap 4, afbeelding 1 van 1
    • Use the Phillips #0 screwdriver to remove the two 4mm screws that are under the rubber pads.
  5. Asus Q504UA-BHI5T13 Heat Sink Replacement: stap 5, afbeelding 1 van 1
    • Insert any of the plastic opening tools into the seam to separate the back cover (it is recommended to start at the corner of the hinges). If you did it right, then the cover should pop off.
    • Be careful as you may damage the tabs.
  6. Asus Q504UA-BHI5T13 Heat Sink Replacement, Heat Sink: stap 6, afbeelding 1 van 1
    • Once the back cover is removed, have the laptop facing upside down with the hinges facing nearest to you.
  7. Asus Q504UA-BHI5T13 Heat Sink Replacement: stap 7, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, remove the three black 4mm screws located around the heat sink fan.
  8. Asus Q504UA-BHI5T13 Heat Sink Replacement: stap 8, afbeelding 1 van 1
    • Using the same screwdriver, remove the four 4mm black screws around the copper lining
    • First remove the screw in the red circle.
    • Then remove the screw in the orange circle.
    • Next remove the screw in the yellow circle.
    • Finally, remove the screw in the green circle.
    • For this step, it helps to remove the screws in this order to prevent damage to the heat sink.
  9. Asus Q504UA-BHI5T13 Heat Sink Replacement: stap 9, afbeelding 1 van 2 Asus Q504UA-BHI5T13 Heat Sink Replacement: stap 9, afbeelding 2 van 2
    • Use a pair of tweezers to pull and disconnect the cable located to the right of the heat sink fan.
    • Take caution when removing the cable. Damaging the cable will stop the part from working.
  10. Asus Q504UA-BHI5T13 Heat Sink Replacement: stap 10, afbeelding 1 van 1
    • Carefully unravel the cables (two black and one white) to the left of the heat sink fan.
  11. Asus Q504UA-BHI5T13 Heat Sink Replacement: stap 11, afbeelding 1 van 1
    • Remove the heat sink from the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Johnathan Teav
456 Reputatie
3 handleidingen geschreven
USF Tampa, Team S10-G4, Thompson Fall 2017 Lid van USF Tampa, Team S10-G4, Thompson Fall 2017
USFT-THOMPSON-F17S10G4
4 Leden
5 handleidingen geschreven
Één opmerking
Where did you buy the  ''heat sink from.
Paul Sullivan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 12
Altijd: 620
