Ga door naar hoofdinhoud
Asus Q503UA-BSI5T17 Hard Drive Removal
Wat je nodig hebt
  1. Asus Q503UA-BSI5T17 Hard Drive Removal, Battery Replacement: stap 1, afbeelding 1 van 1
    • Flip the computer upside down. In order to ensure that the correct side is up, you should be able to read the sticker that indicates the serial number on the bottom.
  2. Asus Q503UA-BSI5T17 Hard Drive Removal: stap 2, afbeelding 1 van 2 Asus Q503UA-BSI5T17 Hard Drive Removal: stap 2, afbeelding 2 van 2
    • Remove the ten circled screws along the perimeter of the laptop with a Phillips #0 screwdriver.
  3. Asus Q503UA-BSI5T17 Hard Drive Removal: stap 3, afbeelding 1 van 3 Asus Q503UA-BSI5T17 Hard Drive Removal: stap 3, afbeelding 2 van 3 Asus Q503UA-BSI5T17 Hard Drive Removal: stap 3, afbeelding 3 van 3
    • Starting from the top right corner, use a plastic prying tool to separate the cover from the laptop. Use light pressure to prevent the plastic from breaking.
    • You should feel the frame coming loose. If necessary, use spacers to keep the frame from locking back into place.
    • Repeat the above step around the laptop until you are able to lift the cover.
  4. Asus Q503UA-BSI5T17 Hard Drive Removal, Battery: stap 4, afbeelding 1 van 1
    • Remove the five screws holding the battery in place using a Phillips #0 screwdriver.
    • Screw locations are approximate. If you find screws to be located elsewhere, please update this step with their correct locations.
  5. Asus Q503UA-BSI5T17 Hard Drive Removal: stap 5, afbeelding 1 van 1
    • Disconnect the battery connection.
  6. Asus Q503UA-BSI5T17 Hard Drive Removal: stap 6, afbeelding 1 van 1
    • Grab and lift the battery from the top right-hand side.
    • If all screws are removed, it should come out with no struggle at all.
  7. Asus Q503UA-BSI5T17 Hard Drive Removal, Hard Drive: stap 7, afbeelding 1 van 2 Asus Q503UA-BSI5T17 Hard Drive Removal, Hard Drive: stap 7, afbeelding 2 van 2
    • Once you opened the laptop, the hard drive is located on the bottom right from where the battery is.
  8. Asus Q503UA-BSI5T17 Hard Drive Removal: stap 8, afbeelding 1 van 2 Asus Q503UA-BSI5T17 Hard Drive Removal: stap 8, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to unscrew the four screws surrounding the hard drive.
  9. Asus Q503UA-BSI5T17 Hard Drive Removal: stap 9, afbeelding 1 van 2 Asus Q503UA-BSI5T17 Hard Drive Removal: stap 9, afbeelding 2 van 2
    • Disconnect the cable that is connected to the hard drive by lifting the edge slightly and sliding it horizontally away from the connector.
    • Remove the hard drive.
    • You may need to further remove the metal mounting brackets from your old hard drive then install them on your new hard drive before reinstallation.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Orlando Garcia
359 Reputatie
2 handleidingen geschreven
Gateway, Team S1-G4, Saknee Fall 2019 Lid van Gateway, Team S1-G4, Saknee Fall 2019
GCC-SAKNEE-F19S1G4
4 Leden
5 handleidingen geschreven
2 opmerkingen
Very easy to do. Directions were easy to follow.
Roxann Jackson - Antwoord
Does this laptop have an M.2 nvme SDD slot?
Isaias Perea - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 1,014
