Ga door naar hoofdinhoud
Asus Q503UA Battery Replacement
Wat je nodig hebt
  1. Asus Q503UA Battery  Replacement, Battery Replacement: stap 1, afbeelding 1 van 1
    • Flip the computer upside down. In order to ensure that the correct side is up, you should be able to read the sticker that indicates the serial number on the bottom.
  2. Asus Q503UA Battery  Replacement: stap 2, afbeelding 1 van 2 Asus Q503UA Battery  Replacement: stap 2, afbeelding 2 van 2
    • Remove the ten circled screws along the perimeter of the laptop with a Phillips #0 screwdriver.
  3. Asus Q503UA Battery  Replacement: stap 3, afbeelding 1 van 3 Asus Q503UA Battery  Replacement: stap 3, afbeelding 2 van 3 Asus Q503UA Battery  Replacement: stap 3, afbeelding 3 van 3
    • Starting from the top right corner, use a plastic prying tool to separate the cover from the laptop. Use light pressure to prevent the plastic from breaking.
    • You should feel the frame coming loose. If necessary, use spacers to keep the frame from locking back into place.
    • Repeat the above step around the laptop until you are able to lift the cover.
  4. Asus Q503UA Battery  Replacement, Battery: stap 4, afbeelding 1 van 1
    • Remove the five screws holding the battery in place using a Phillips #0 screwdriver.
    • Screw locations are approximate. If you find screws to be located elsewhere, please update this step with their correct locations.
  5. Asus Q503UA Battery  Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the battery connection.
  6. Asus Q503UA Battery  Replacement: stap 6, afbeelding 1 van 1
    • Grab and lift the battery from the top right-hand side.
    • If all screws are removed, it should come out with no struggle at all.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Roberto Apodaca
342 Reputatie
2 handleidingen geschreven
Gateway, Team S1-G4, Saknee Fall 2019 Lid van Gateway, Team S1-G4, Saknee Fall 2019
GCC-SAKNEE-F19S1G4
4 Leden
5 handleidingen geschreven
1Gids Commentaar
Great Instruction. Too bad reasonably priced replacements are no longer available new. I spent hours on the net using numerous search engines, The only new ones were in the hundreds of dollars, and who wants to buy used ones?
Don Dattler - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 27
Altijd: 3,456
