Ga door naar hoofdinhoud
Asus Q502LA-BSI5T14 Battery Replacement
Wat je nodig hebt
  1. Asus Q502LA-BSI5T14 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Ensure your device is powered off before starting.
    • Flip the laptop over and remove the ten 10 mm Phillips #1 screws securing the back panel.
  2. Asus Q502LA-BSI5T14 Battery Replacement: stap 2, afbeelding 1 van 1
    • Carefully insert a plastic opening tool under one corner of the back panel.
    • Slide the tool along the seam to gently pry the panel up and away from the device.
  3. Asus Q502LA-BSI5T14 Battery Replacement: stap 3, afbeelding 1 van 2 Asus Q502LA-BSI5T14 Battery Replacement: stap 3, afbeelding 2 van 2
    • The battery is the large L-shaped block.
    • Remove the five 5.5 mm Phillips #1 screws securing it.
  4. Asus Q502LA-BSI5T14 Battery Replacement: stap 4, afbeelding 1 van 2 Asus Q502LA-BSI5T14 Battery Replacement: stap 4, afbeelding 2 van 2
    • Using a plastic opening tool, lift the battery straight upward to remove it.
    • There are a series of eight small wires connecting the battery to the motherboard. Make sure you gently lift the battery straight up to disconnect these wires and prevent damage.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Mary Kounelas
742 Reputatie
5 handleidingen geschreven
USF Tampa, Team S4-G1, Eyestone Fall 2017 Lid van USF Tampa, Team S4-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S4G1
4 Leden
2 opmerkingen
Got as far as the removal from wires. How is that done. A total newbie. I just lifted the battery slightly. Would this help with the static or do I totally need to remove the battery? Laptop shows battery is almost fully charged. There is not a green light.
Berta Stoffel - Antwoord
Mine has no green light at first but after battery reaches full state it is there. However annoyingly flickers (screen and all) between charge state and discharging at full. Luckily seems to work fine across the whole range of charging. Can't believe this Q502LA is still holding on after 8 years :) Wondering if there is any battery drive/update?
jsbenami - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 4,595
