Ga door naar hoofdinhoud
Asus Q501LA-BBI6T03 Back Panel Replacement
Wat je nodig hebt
  1. Asus Q501LA-BBI6T03 Back Panel Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Ensure the laptop is powered down before continuing.
    • Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
  2. Asus Q501LA-BBI6T03 Back Panel Replacement: stap 2, afbeelding 1 van 1
    • Use the spudger to pry open the rear cover at either hinge.
  3. Asus Q501LA-BBI6T03 Back Panel Replacement: stap 3, afbeelding 1 van 2 Asus Q501LA-BBI6T03 Back Panel Replacement: stap 3, afbeelding 2 van 2
    • Grab the cover with your fingers and gently lift it away from the board.
    • Be careful not to break any tabs on the cover when lifting it off.
    This step took me about an hour of careful prying. I didn’t break any real tabs, but tiny rectangular chips of plastic still came off. It felt like the cover had been sealed to the board, so I couldn’t just lift it off.
    Suzanne Yee - Antwoord
Conclusie
Tanner
276 Reputatie
2 handleidingen geschreven
Cal Poly, Team 8-1, Banghart Winter 2017 Lid van Cal Poly, Team 8-1, Banghart Winter 2017
CPSU-BANGHART-W17S8G1
3 Leden
6 handleidingen geschreven
Één opmerking
I got one of these model, how much RAM is the maximum amount supported?
Cesar Aguilar - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 627
