Inleiding
This guide will show you the steps to replace the motherboard in an ASUS Q325U.
Wat je nodig hebt
Remove the seven 5mm screws around the battery using a Phillips #00 screwdriver.
Gereedschap gebruikt in deze stap:Halberd Spudger$2.99
Remove the first connection wire by pulling the small back loop with the Halberd Spudger.
Bijna klaar!
Conclusie
