Inleiding
This guide will take you through the steps needed to replace the battery in your Asus Q325U.
Wat je nodig hebt
Remove the seven 5mm screws around the battery using a Phillips #00 screwdriver.
4 andere personen hebben deze handleiding voltooid.
7 opmerkingen
Hello,
Can you point me to a place to purchase a replacement battery? Thanks,
Dan Goldman, daniel.goldman@physics.gatech.edu
Would recommend the screw size be ad to the guide please.
Like Dan, I need to get a replacement battery. Any idea where it can be purchased (safely)?
Thanks :D
not able to get beyond step 4. Any ideas how to open the small screws. I tried PH#000, and many others, but no luck
the battery shown here is not the same for the Q325U, different battery connectors.
