Ga door naar hoofdinhoud
Asus Q304UA Hard Drive Replacement
Wat je nodig hebt
  1. Asus Q304UA Hard Drive Replacement, Remove Bottom Cover: stap 1, afbeelding 1 van 1
    • Remove ten Phillips #0 screws that secure the plastic bottom cover to the chassis.
    • Six 9.6 mm screws
    • Four 4.6 mm screws
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  2. Asus Q304UA Hard Drive Replacement: stap 2, afbeelding 1 van 3 Asus Q304UA Hard Drive Replacement: stap 2, afbeelding 2 van 3 Asus Q304UA Hard Drive Replacement: stap 2, afbeelding 3 van 3
    • Use a plastic pry tool to get in-between the bottom cover and the lower case assembly.
    • Be careful not separate the cover too violently or you will risk breaking the plastic clips that are on the bottom cover.
  3. Asus Q304UA Hard Drive Replacement, Disconnect the battery: stap 3, afbeelding 1 van 3 Asus Q304UA Hard Drive Replacement, Disconnect the battery: stap 3, afbeelding 2 van 3 Asus Q304UA Hard Drive Replacement, Disconnect the battery: stap 3, afbeelding 3 van 3
    • Push metal bracket away from battery connector.
    • Use a spudger to push the battery connection straight up.
    • If you pry too hard, or attempt to disconnect the battery with the metal bracket still in place, you risk pulling the connector off of the motherboard.
    • Make sure the computer is powered off before removing the battery.
  4. Asus Q304UA Hard Drive Replacement, Disconnect RF Cables: stap 4, afbeelding 1 van 3 Asus Q304UA Hard Drive Replacement, Disconnect RF Cables: stap 4, afbeelding 2 van 3 Asus Q304UA Hard Drive Replacement, Disconnect RF Cables: stap 4, afbeelding 3 van 3
    • Disconnect the Wifi/Bluetooth RF cables from the wireless card.
    • Pull the RF cables by the metal connector, not by the rubber shielding. This avoids damaging the connector and the cable.
  5. Asus Q304UA Hard Drive Replacement, Hard Drive Assembly: stap 5, afbeelding 1 van 2 Asus Q304UA Hard Drive Replacement, Hard Drive Assembly: stap 5, afbeelding 2 van 2
    • Pull straight up to disconnect the SATA combo cable from the motherboard.
  6. Asus Q304UA Hard Drive Replacement: stap 6, afbeelding 1 van 1
    • Remove three Phillips #0 that secure the hard drive bracket to the chassis, of the following lengths:
    • Two 2.3 mm screws
    • One 5.6 mm screw
  7. Asus Q304UA Hard Drive Replacement: stap 7, afbeelding 1 van 3 Asus Q304UA Hard Drive Replacement: stap 7, afbeelding 2 van 3 Asus Q304UA Hard Drive Replacement: stap 7, afbeelding 3 van 3
    • Tilt the drive up slightly by the connector
    • Remove the SATA combo connector
  8. Asus Q304UA Hard Drive Replacement: stap 8, afbeelding 1 van 2 Asus Q304UA Hard Drive Replacement: stap 8, afbeelding 2 van 2
    • De-route the SATA and RF cables from the side of the drive bay.
  9. Asus Q304UA Hard Drive Replacement: stap 9, afbeelding 1 van 1
    • Insert wisdom here.
  10. Asus Q304UA Hard Drive Replacement, Hard Drive Bracket Assembly: stap 10, afbeelding 1 van 2 Asus Q304UA Hard Drive Replacement, Hard Drive Bracket Assembly: stap 10, afbeelding 2 van 2
    • Remove the four Phillips #0 screws that secure the hard drive to the hard drive bracket.
    • Four 3.7 mm screws
  11. Asus Q304UA Hard Drive Replacement: stap 11, afbeelding 1 van 3 Asus Q304UA Hard Drive Replacement: stap 11, afbeelding 2 van 3 Asus Q304UA Hard Drive Replacement: stap 11, afbeelding 3 van 3
    • Peal back thermal cover.
    • Be careful not to tear the cover on the side of the drive as you peel it off.
  12. Asus Q304UA Hard Drive Replacement: stap 12, afbeelding 1 van 1
    • Remove drive from hard drive bracket.
Conclusie
3 andere personen hebben deze handleiding voltooid.
iHelpU.Tech
3.558 Reputatie
5 handleidingen geschreven
iHelpU.tech Lid van iHelpU.tech
Business
2 Leden
16 handleidingen geschreven
Één opmerking
This should be rated moderate. Easy is sliding out a drive bay on a old Dell laptop from 15 years ago. :)
Michael Maxson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 21
Altijd: 5,121
