Ga door naar hoofdinhoud
Asus Padfone X Mini Speaker Replacement
Wat je nodig hebt
  1. Asus Padfone X Mini Speaker Replacement, Speaker: stap 1, afbeelding 1 van 1
    • With the phone facing down, look at the bottom right side corner and there should be a groove. Use a plastic opening tool and lift up to remove outside cover.
    • This is not the cover with the speaker attached.
  2. Asus Padfone X Mini Speaker Replacement: stap 2, afbeelding 1 van 1
    • Lift the battery out from the top of the device.
  3. Asus Padfone X Mini Speaker Replacement: stap 3, afbeelding 1 van 1
    • Around the perimeter, there should be 10 2 mm T5 Torx screws. Take them out.
    • Remove the cover.
  4. Asus Padfone X Mini Speaker Replacement: stap 4, afbeelding 1 van 1
    • Turn the cover over.
    • The speaker is attached to the inside of the cover and to the right of the camera hole.
  5. Asus Padfone X Mini Speaker Replacement: stap 5, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove speaker with standard tweezers to minimize damage, and replace.
Conclusie
Nicolette Carr
383 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 156
