Ga door naar hoofdinhoud
Asus Padfone X Mini Camera Replacement
Wat je nodig hebt
  1. Asus Padfone X Mini Camera Replacement, Speaker: stap 1, afbeelding 1 van 1
    • With the phone facing down, look at the bottom right side corner and there should be a groove. Use a plastic opening tool and lift up to remove outside cover.
    • This is not the cover with the speaker attached.
  2. Asus Padfone X Mini Camera Replacement: stap 2, afbeelding 1 van 1
    • Lift the battery out from the top of the device.
  3. Asus Padfone X Mini Camera Replacement: stap 3, afbeelding 1 van 1
    • Around the perimeter, there should be 10 2 mm T5 Torx screws. Take them out.
    • Remove the cover.
  4. Asus Padfone X Mini Camera Replacement: stap 4, afbeelding 1 van 1
    • Turn the cover over.
    • The speaker is attached to the inside of the cover and to the right of the camera hole.
  5. Asus Padfone X Mini Camera Replacement: stap 5, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove speaker with standard tweezers to minimize damage, and replace.
  6. Asus Padfone X Mini Camera Replacement, Screen: stap 6, afbeelding 1 van 1
    • Detach the black connector on the left hand side of the motherboard.
    • Don't completely remove the black connector.
  7. Asus Padfone X Mini Camera Replacement: stap 7, afbeelding 1 van 1
    • Disconnect silver connector from the motherboard. It is located on the left hand side above the black connector.
  8. Asus Padfone X Mini Camera Replacement: stap 8, afbeelding 1 van 2 Asus Padfone X Mini Camera Replacement: stap 8, afbeelding 2 van 2
    • Remove motherboard and replace screen.
  9. Asus Padfone X Mini Camera Replacement, Camera: stap 9, afbeelding 1 van 1
    • Turn over the motherboard.
  10. Asus Padfone X Mini Camera Replacement: stap 10, afbeelding 1 van 1
    Koop
    • Using tweezers pull out the connector that connects the camera to the motherboard.
  11. Asus Padfone X Mini Camera Replacement: stap 11, afbeelding 1 van 2 Asus Padfone X Mini Camera Replacement: stap 11, afbeelding 2 van 2
    • Take out the camera.
    • Put in the new camera by sliding the camera connector into the receiver.
Conclusie
James Jackson
97 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 196
