Ga door naar hoofdinhoud
Asus Padfone 2 Camera Replacement
Wat je nodig hebt
  1. Asus Padfone 2 Camera  Replacement, Power Down Device: stap 1, afbeelding 1 van 1
    • Hold down the power button.
  2. Asus Padfone 2 Camera  Replacement, Remove Back Plate: stap 2, afbeelding 1 van 3 Asus Padfone 2 Camera  Replacement, Remove Back Plate: stap 2, afbeelding 2 van 3 Asus Padfone 2 Camera  Replacement, Remove Back Plate: stap 2, afbeelding 3 van 3
    • Use plastic opening tool to pry off the back cover of the phone.
  3. Asus Padfone 2 Camera  Replacement, Battery Removal: stap 3, afbeelding 1 van 3 Asus Padfone 2 Camera  Replacement, Battery Removal: stap 3, afbeelding 2 van 3 Asus Padfone 2 Camera  Replacement, Battery Removal: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Remove the warning sticker that covers the battery plug and connecting cord.
    • Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
    • The battery is held down with adhesive. Be careful not to damage battery or connecting cord.
    • Disconnect battery connecting cord using tweezers.
  4. Asus Padfone 2 Camera  Replacement, Remove Internal Back Plate: stap 4, afbeelding 1 van 3 Asus Padfone 2 Camera  Replacement, Remove Internal Back Plate: stap 4, afbeelding 2 van 3 Asus Padfone 2 Camera  Replacement, Remove Internal Back Plate: stap 4, afbeelding 3 van 3
    • Use T5 Torx screwdriver to remove 14 screws from internal back plate.
    • Use of magnetic pad will help with keeping track of screws.
    • Once screws are out, remove the plate.
  5. Asus Padfone 2 Camera  Replacement, Disconnect Motherboard: stap 5, afbeelding 1 van 3 Asus Padfone 2 Camera  Replacement, Disconnect Motherboard: stap 5, afbeelding 2 van 3 Asus Padfone 2 Camera  Replacement, Disconnect Motherboard: stap 5, afbeelding 3 van 3
    • Disconnect four plugs to the motherboard using tweezers.
    • Lift up green motherboard.
  6. Asus Padfone 2 Camera  Replacement, Removing Camera: stap 6, afbeelding 1 van 2 Asus Padfone 2 Camera  Replacement, Removing Camera: stap 6, afbeelding 2 van 2
    • Remove camera from back of the motherboard with tweezers.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Erica
482 Reputatie
2 handleidingen geschreven
USF Tampa, Team 5-4, Mcgee Fall 2014 Lid van USF Tampa, Team 5-4, Mcgee Fall 2014
USFT-MCGEE-F14S5G4
4 Leden
7 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 50
Altijd: 2,231
