Ga door naar hoofdinhoud
Asus Padfone 2 Battery Replacement
Wat je nodig hebt
  1. Asus Padfone 2 Battery Replacement, Power off phone: stap 1, afbeelding 1 van 1
    • Hold down power button to shut off phone.
  2. Asus Padfone 2 Battery Replacement, Remove back cover of phone: stap 2, afbeelding 1 van 2 Asus Padfone 2 Battery Replacement, Remove back cover of phone: stap 2, afbeelding 2 van 2
    • Use plastic opening tool to pry off the back cover of the phone.
  3. Asus Padfone 2 Battery Replacement, Battery Removal: stap 3, afbeelding 1 van 3 Asus Padfone 2 Battery Replacement, Battery Removal: stap 3, afbeelding 2 van 3 Asus Padfone 2 Battery Replacement, Battery Removal: stap 3, afbeelding 3 van 3
    • Remove the warning sticker that covers the battery plug and connecting cord.
    • Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
    • The battery is held down with adhesive. Be careful not to damage battery or connecting cord
    • Disconnect battery connecting cord using tweezers.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Zach Standridge
350 Reputatie
2 handleidingen geschreven
USF Tampa, Team 5-4, Mcgee Fall 2014 Lid van USF Tampa, Team 5-4, Mcgee Fall 2014
USFT-MCGEE-F14S5G4
4 Leden
7 handleidingen geschreven
Één opmerking
Pull the battery connector towards USB. You will break it if you pull it up, as I did.
I wouldn’t recommend metal tweezers as it could shortcut the battery.
Los Karlos - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 5,826
