Ga door naar hoofdinhoud
Asus PadFone S Motherboard Replacement
Wat je nodig hebt
  1. Asus PadFone S Motherboard Replacement, Remove the Back Panel: stap 1, afbeelding 1 van 1
    • Place your thumb in the charging port and pry the back cover off of the phone.
  2. Asus PadFone S Motherboard Replacement, Remove the Back Panel: stap 2, afbeelding 1 van 2 Asus PadFone S Motherboard Replacement, Remove the Back Panel: stap 2, afbeelding 2 van 2
    • Remove all screws using the T5 Torx screwdriver
    • Lift the back panel off the phone.
  3. Asus PadFone S Motherboard Replacement, Remove the Battery: stap 3, afbeelding 1 van 2 Asus PadFone S Motherboard Replacement, Remove the Battery: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Disconnect the battery from the logic board using tweezers
    • Using the plastic opening tools, lift the battery up from its slot
    • Apply consistent, steady force to lift the battery from its slot. Be careful not to damage the battery while removing it.
  4. Asus PadFone S Motherboard Replacement, Disconnect the Logic Board: stap 4, afbeelding 1 van 3 Asus PadFone S Motherboard Replacement, Disconnect the Logic Board: stap 4, afbeelding 2 van 3 Asus PadFone S Motherboard Replacement, Disconnect the Logic Board: stap 4, afbeelding 3 van 3
    • Disconnect all wires and bands from microphone, SIM card port and side bottons
  5. Asus PadFone S Motherboard Replacement, Remove the Logic Board: stap 5, afbeelding 1 van 3 Asus PadFone S Motherboard Replacement, Remove the Logic Board: stap 5, afbeelding 2 van 3 Asus PadFone S Motherboard Replacement, Remove the Logic Board: stap 5, afbeelding 3 van 3
    • Disconnect remaining band from the logic board
    • Lift the logic board out of the phone
Conclusie
Greg Betsold
96 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014 Lid van UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G1
3 Leden
10 handleidingen geschreven
Één opmerking
need schematic side button asus padfone s..please send via email kepkep.erwin@gmail.com.
thanks..
kepkep - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 3,606
