Ga door naar hoofdinhoud
Asus PadFone S Front Facing Camera Replacement
Wat je nodig hebt
  1. Asus PadFone S Front Facing Camera Replacement, Remove the Back Panel: stap 1, afbeelding 1 van 1
    • Place your thumb in the charging port and pry the back cover off of the phone.
  2. Asus PadFone S Front Facing Camera Replacement, Remove the Back Panel: stap 2, afbeelding 1 van 2 Asus PadFone S Front Facing Camera Replacement, Remove the Back Panel: stap 2, afbeelding 2 van 2
    • Remove all screws using the T5 Torx screwdriver
    • Lift the back panel off the phone.
  3. Asus PadFone S Front Facing Camera Replacement, Remove the Battery: stap 3, afbeelding 1 van 2 Asus PadFone S Front Facing Camera Replacement, Remove the Battery: stap 3, afbeelding 2 van 2
    • Disconnect the battery from the logic board using tweezers
    • Using the plastic opening tools, lift the battery up from its slot
    • Apply consistent, steady force to lift the battery from its slot. Be careful not to damage the battery while removing it.
  4. Asus PadFone S Front Facing Camera Replacement, Front Facing Camera: stap 4, afbeelding 1 van 3 Asus PadFone S Front Facing Camera Replacement, Front Facing Camera: stap 4, afbeelding 2 van 3 Asus PadFone S Front Facing Camera Replacement, Front Facing Camera: stap 4, afbeelding 3 van 3
    • Once the Battery has been successfully removed, move on to the step 2.
  5. Asus PadFone S Front Facing Camera Replacement, Start of Logic Board Removal: stap 5, afbeelding 1 van 2 Asus PadFone S Front Facing Camera Replacement, Start of Logic Board Removal: stap 5, afbeelding 2 van 2
    • Disconnect the marked strips from the logic board using the tweezers.
    • Applying too much force may damage the strips/connectors.
    • Remember to remove speaker connection located at the bottom left hand corner.
  6. Asus PadFone S Front Facing Camera Replacement, Logic Board Removal - Continued: stap 6, afbeelding 1 van 2 Asus PadFone S Front Facing Camera Replacement, Logic Board Removal - Continued: stap 6, afbeelding 2 van 2
    • Disconnect the other two strips that connect the logic board to the phone.
  7. Asus PadFone S Front Facing Camera Replacement, Remove The Camera: stap 7, afbeelding 1 van 2 Asus PadFone S Front Facing Camera Replacement, Remove The Camera: stap 7, afbeelding 2 van 2
    • Turn over the logic board to locate the front camera.
    • Grasp the sides of the camera with the tweezers and carefully remove the camera from the logic board.
    • Applying to much force will damage the connective strip.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Everette Gonsalves
26 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014 Lid van UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G1
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 7
Altijd: 1,500
