Inleiding
You will learn how to replace the camera. Review this guide if you are having difficulties with the camera. In order to replace the camera, you have to remove the battery and motherboard. Please use our Asus MeMO Pad HD 8 ME180A Battery Replacement Guide and Asus MeMO Pad HD 8 ME180A Motherboard Replacement Guide to do so prior to starting.
Wat je nodig hebt
Use a plastic opening tool to separate the back half from the front half.
Pull the back panel away from the device.
Gereedschap gebruikt in deze stap:Anti-Static Wrist Strap$7.95
Ensure that you are wearing your Anti-Static Wrist Strap.
Upon removal of the motherboard, flip the motherboard to the side so the front-face camera faces you.
Remove the front facing camera.
