Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Carefully remove the back panel by using a plastic opening tool to remove the panel off the device.
Pull the back panel away from the device.
Unlock the ZIF connectors on the data cables.
Remove the cable from its slot by gently pulling downward on the tabs.
Locate the battery connector by following the wires that come from the top right of the battery. To disconnect the battery just lift up gently on the wires. Use a spudger or blue plastic opening tool to gently lift the wires if it is hard to get a grip.
Using a spudger carefully pry the battery up. It is glued down so slight pressure may be needed.
14 andere personen hebben deze handleiding voltooid.
4 opmerkingen
How did you fix the sd card port?
where can i buy battery for asus memopad here in naga city, cam sur,philippines?
