Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Use this guide to replace a faulty battery in you ASUS MeMO Pad 8.
Wat je nodig hebt
Insert a plastic opening tool into the seam between the rear case and the screen.
Work the plastic opening tool around the perimeter of the device to completely remove the rear case.
Use the flat end of the nylon spudger to flip up the retaining flap of the Zero Insertion Force (ZIF) connector holding the orange motherboard ribbon cable in place.
7 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Great instructions and easy disassembly/reassembly. Photos really helped!
