Ga door naar hoofdinhoud
Asus MeMO Pad 7 ME176C Speaker Replacement
Wat je nodig hebt
  1. Asus MeMO Pad 7 ME176C Speaker Replacement, Speakers: stap 1, afbeelding 1 van 2 Asus MeMO Pad 7 ME176C Speaker Replacement, Speakers: stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    iFixit Opening Tool
    $1.99
    • Make sure the device is turned off.
    • Carefully insert the opening tool on the edge of the phone.
    • Slowly lift up the panel from the device and repeat the process on the other side.
  2. Asus MeMO Pad 7 ME176C Speaker Replacement: stap 2, afbeelding 1 van 3 Asus MeMO Pad 7 ME176C Speaker Replacement: stap 2, afbeelding 2 van 3 Asus MeMO Pad 7 ME176C Speaker Replacement: stap 2, afbeelding 3 van 3
    • To disconnect the ZIF connectors. Place the metal spudger underneath the ZIF cable and gently pull it outward.
    • ZIF connectors are fragile, so work with caution.
  3. Asus MeMO Pad 7 ME176C Speaker Replacement: stap 3, afbeelding 1 van 3 Asus MeMO Pad 7 ME176C Speaker Replacement: stap 3, afbeelding 2 van 3 Asus MeMO Pad 7 ME176C Speaker Replacement: stap 3, afbeelding 3 van 3
    • The battery connector is located on the right-hand side of the device
    • To disconnect the battery connector. Use tweezers, and carefully lift up the wire.
    • Remove the battery.
  4. Asus MeMO Pad 7 ME176C Speaker Replacement: stap 4, afbeelding 1 van 1
    • Using a Philips Head Screwdriver PH000, locate the 2.6mm screws and gently unscrew them .
    • Place these screws somewhere you will remember.
    • Applying too much pressure onto the screen may cause it to break.
  5. Asus MeMO Pad 7 ME176C Speaker Replacement: stap 5, afbeelding 1 van 3 Asus MeMO Pad 7 ME176C Speaker Replacement: stap 5, afbeelding 2 van 3 Asus MeMO Pad 7 ME176C Speaker Replacement: stap 5, afbeelding 3 van 3
    • Using tweezers, disconnect the speaker cable connected to the motherboard.
    • Be sure not to damage other components on the motherboard.
    • After that remove the speaker system completely.
  6. Asus MeMO Pad 7 ME176C Speaker Replacement: stap 6, afbeelding 1 van 1
    • Now you can attach a new speaker!
Conclusie
Maxime
101 Reputatie
1 Handleiding geschreven
Cal Poly, Team S6-G3, Banghart Fall 2017 Lid van Cal Poly, Team S6-G3, Banghart Fall 2017
CPSU-BANGHART-F17S6G3
5 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 254
