Ga door naar hoofdinhoud
Asus MeMO Pad 7 ME176C Motherboard Replacement
Wat je nodig hebt
  1. Asus MeMO Pad 7 ME176C Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 2 Asus MeMO Pad 7 ME176C Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 2
    • Before taking anything apart, first make sure the device is turned completely off.
    • The device is somewhat fragile so beware not to put too much force on the screen.
    • Use a opening tool to pry open the backside cover of the device. Gently pry the backside open all around.
  2. Asus MeMO Pad 7 ME176C Motherboard Replacement: stap 2, afbeelding 1 van 2 Asus MeMO Pad 7 ME176C Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Locate a black connector that is attached from the battery to the motherboard.
    • Gently slide the connector out with the opening tool by pushing it back, to avoid damaging any part.
  3. Asus MeMO Pad 7 ME176C Motherboard Replacement: stap 3, afbeelding 1 van 3 Asus MeMO Pad 7 ME176C Motherboard Replacement: stap 3, afbeelding 2 van 3 Asus MeMO Pad 7 ME176C Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Locate the battery and area where a strip of wire is connected to the motherboard.
    • Use a nylon spudger or something which you can easily push back and slide the wire out carefully from the motherboard connector.
    • Then peel back the tape connecting the wire to the battery on both ends and lift the wire off the battery.
    • Gently slide a plastic spudger between the battery and the housing to free the adhesive. Work the spudger from side to side to gradually free the battery.
    • Do not use a metal tool to remove the battery; avoid bending or puncturing the battery during removal.
  4. Asus MeMO Pad 7 ME176C Motherboard Replacement: stap 4, afbeelding 1 van 2 Asus MeMO Pad 7 ME176C Motherboard Replacement: stap 4, afbeelding 2 van 2
    • On the right side of the tablet there is a small black connector.
    • Using a small tool, carefully slide back the connector from the motherboard.
  5. Asus MeMO Pad 7 ME176C Motherboard Replacement: stap 5, afbeelding 1 van 1
    • On the top right there is a small connector that connects to the motherboard.
    • This connector is a small wire. Be careful not to damage the wire.
    • Using the tweezer tool, carefully slide out the connector from the motherboard.
  6. Asus MeMO Pad 7 ME176C Motherboard Replacement: stap 6, afbeelding 1 van 2 Asus MeMO Pad 7 ME176C Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Next to the previous connector on the top right, there is another large connector.
    • Disconnect using a tweezer or a tool to easily slide the connector out.
  7. Asus MeMO Pad 7 ME176C Motherboard Replacement: stap 7, afbeelding 1 van 2 Asus MeMO Pad 7 ME176C Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Locate the screws around the motherboard.
    • Unscrew the screws using a Phillips Head Screwdriver PH000 around the motherboard.
    • Caution: Carefully place the screws in a safe place as you will need them to put back the motherboard.
  8. Asus MeMO Pad 7 ME176C Motherboard Replacement: stap 8, afbeelding 1 van 3 Asus MeMO Pad 7 ME176C Motherboard Replacement: stap 8, afbeelding 2 van 3 Asus MeMO Pad 7 ME176C Motherboard Replacement: stap 8, afbeelding 3 van 3
    • On the bottom right of the motherboard, there is a small opening.
    • Using a prying tool, gently pop up the motherboard.
Conclusie
hmedina777
101 Reputatie
1 Handleiding geschreven
Cal Poly, Team S6-G3, Banghart Fall 2017 Lid van Cal Poly, Team S6-G3, Banghart Fall 2017
CPSU-BANGHART-F17S6G3
5 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 1,213
