Ga door naar hoofdinhoud
Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement
Wat je nodig hebt
  1. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement, LCD Screen Assembly: stap 1, afbeelding 1 van 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement, LCD Screen Assembly: stap 1, afbeelding 2 van 2
    • Insert plastic opening tool in between screen and back cover to create initial separation between the two.
    • Then run plastic opening tool along end of screen to fully separate back cover from screen.
  2. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: stap 2, afbeelding 1 van 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: stap 2, afbeelding 2 van 2
    • Remove screws (2.6mm) connecting speaker to hard frame with Phillips head screw driver (PH000).
  3. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Disconnect speaker wire from motherboard using metal pronged tweezers.
  4. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: stap 4, afbeelding 1 van 1
    • Remove the screws (2.6mm) connecting the motherboard and battery tray to the hard frame with Phillip's head screw driver (PH000).
  5. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: stap 5, afbeelding 1 van 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: stap 5, afbeelding 2 van 2
    • Remove the black bundle battery connector from the motherboard using plastic opening tools.
  6. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: stap 6, afbeelding 1 van 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: stap 6, afbeelding 2 van 2
    • Use plastic opener tool to disconnect ZIF connectors as shown.
  7. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: stap 7, afbeelding 1 van 3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: stap 7, afbeelding 2 van 3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: stap 7, afbeelding 3 van 3
    • Remove speaker housing to expose ZIF connection underneath.
    • Then using metal tweezers disconnect the ZIF connector.
  8. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: stap 8, afbeelding 1 van 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: stap 8, afbeelding 2 van 2
    • Remove display and button connections from motherboard using metal tweezers.
  9. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: stap 9, afbeelding 1 van 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: stap 9, afbeelding 2 van 2
    • Remove unscrewed battery tray from main frame.
  10. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: stap 10, afbeelding 1 van 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: stap 10, afbeelding 2 van 2
    • Remove motherboard from hard frame.
    • When removing the motherboard make sure all screws that attach motherboard to hardframe are removed and to release plastic tab as shown in image.
  11. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: stap 11, afbeelding 1 van 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: stap 11, afbeelding 2 van 2
    • Peel off button sensors off the side of the hard frame.
  12. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: stap 12, afbeelding 1 van 3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: stap 12, afbeelding 2 van 3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: stap 12, afbeelding 3 van 3
    • Apply slight pressure on camera to break adhesive to finish screen disassembly processes.
Conclusie
Nejad Harara
110 Reputatie
1 Handleiding geschreven
Cal Poly, Team S6-G3, Banghart Fall 2017 Lid van Cal Poly, Team S6-G3, Banghart Fall 2017
CPSU-BANGHART-F17S6G3
5 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 1,690
