Inleiding
The speaker is where sound comes out. When videos or music are played too loudly, it can cause the speaker to blow. This is a component of the Memo Pad that needs to be replaced when this problem occurs.
Wat je nodig hebt
Using the Jimmy tool, gently wedge it into the seam of the device at the side.
Pry the Jimmy tool gently all around the seam. Use up and down motions until the back panel is detached.
Één andere persoon heeft deze handleiding voltooid.
