Ga door naar hoofdinhoud
Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement
Wat je nodig hebt
  1. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement, Motherboard: stap 1, afbeelding 1 van 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement, Motherboard: stap 1, afbeelding 2 van 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement, Motherboard: stap 1, afbeelding 3 van 3
    • Power off the device before disassembly.
    • Be gentle; excessive force can result in a damaged or cracked screen.
    • Gently pry a Jimmy all around the seam of the device until the back panel detaches.
  2. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 2, afbeelding 1 van 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 2, afbeelding 2 van 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 2, afbeelding 3 van 3
    • Use an iFixit opening tool to gently push the black bundle cable connector in a forward motion until it loosens without pushing down on the bundle cable connector.
  3. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 3, afbeelding 1 van 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 3, afbeelding 2 van 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 3, afbeelding 3 van 3
    • Use the plastic opening tool to pry around the edges of the battery.
    • The battery should be laying freely in its port.
    • Lift the battery out of its port.
  4. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 4, afbeelding 1 van 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 4, afbeelding 2 van 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 4, afbeelding 3 van 3
    • Use a plastic opening tool to slide the white cable connector completely out of the port.
  5. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 5, afbeelding 1 van 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 5, afbeelding 2 van 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Flip up the beige clip to loosen the cable.
    • Use the wide nosed tweezers to pinch the blue tab attached to the ribbon cable.
    • Pull the blue tab gently in a lateral motion until it is completely out of its port.
  6. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 6, afbeelding 1 van 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 6, afbeelding 2 van 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 6, afbeelding 3 van 3
    • Use the wide nosed tweezers to gently pull out the orange ribbon inserted in the port on the motherboard.
  7. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 7, afbeelding 1 van 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 7, afbeelding 2 van 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 7, afbeelding 3 van 3
    • Use a plastic opening tool to push the white cable connector out of its port in a side to side motion.
  8. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 8, afbeelding 1 van 2 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 8, afbeelding 2 van 2
    • Use the Phillips #000 screwdriver to unscrew the seven screws.
    • There should be two silver and five black screws.
  9. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 9, afbeelding 1 van 2 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 9, afbeelding 2 van 2
    • Once the screws are removed, the speaker component will be loosely laying in the track.
    • Use the metal spudger tool to remove the speaker by gently lifting the edge of it.
  10. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 10, afbeelding 1 van 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 10, afbeelding 2 van 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 10, afbeelding 3 van 3
    • Remove the silver tape on one corner with the needle nosed tweezers, and remove the tape from the motherboard.
  11. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 11, afbeelding 1 van 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 11, afbeelding 2 van 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 11, afbeelding 3 van 3
    • Use the needle nosed tweezers to gently pull both of the orange ribbon cables out of their ports.
  12. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 12, afbeelding 1 van 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 12, afbeelding 2 van 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 12, afbeelding 3 van 3
    • Use the Phillips #000 screwdriver to unscrew all five screws.
  13. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 13, afbeelding 1 van 2 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: stap 13, afbeelding 2 van 2
    • To uninstall the motherboard, use the metal spudger tool to lift it out of the device.
  14. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement, Rear Facing Camera: stap 14, afbeelding 1 van 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement, Rear Facing Camera: stap 14, afbeelding 2 van 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement, Rear Facing Camera: stap 14, afbeelding 3 van 3
    • Gently remove grey tape that is holding down connector for camera using the tweezers.
    • When tape is removed, use the plastic prying tool to gently unlock connector between camera wiring and motherboard. The connector lock rotates upward away from motherboard to release.
    • Carefully remove camera from motherboard using tweezers by pulling directly upward. Camera should release easily without much resistance.
Conclusie
Thomas Brooks
301 Reputatie
3 handleidingen geschreven
IUPUI, Team S3-G3, Wilson Spring 2017 Lid van IUPUI, Team S3-G3, Wilson Spring 2017
IUPUI-WILSON-S17S3G3
5 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 154
