Ga door naar hoofdinhoud
Asus MeMO Pad 7 ME170C Power and Volume Button Replacement
Wat je nodig hebt
  1. Asus MeMO Pad 7 ME170C Power and Volume Button Replacement, Battery: stap 1, afbeelding 1 van 3 Asus MeMO Pad 7 ME170C Power and Volume Button Replacement, Battery: stap 1, afbeelding 2 van 3 Asus MeMO Pad 7 ME170C Power and Volume Button Replacement, Battery: stap 1, afbeelding 3 van 3
    • Before beginning to disassemble, Power off the device.
    • Excessive force can result in damaged or cracked screen. Be Gentle.
    • Gently wedge a Jimmy into the seam of the device.
    • Gently pry the Jimmy all around the seam until the back panel is detached.
  2. Asus MeMO Pad 7 ME170C Power and Volume Button Replacement: stap 2, afbeelding 1 van 3 Asus MeMO Pad 7 ME170C Power and Volume Button Replacement: stap 2, afbeelding 2 van 3 Asus MeMO Pad 7 ME170C Power and Volume Button Replacement: stap 2, afbeelding 3 van 3
    • Locate the black bundle cable connector attached to the battery of the phone.
    • Do not push down. Slide in a forward motion to avoid breaking any inner pieces.
    • Using a plastic opening tool, gently slide the black bundle cable connector towards the battery in a back and forth motion until loosened and it slides out of connection port.
  3. Asus MeMO Pad 7 ME170C Power and Volume Button Replacement: stap 3, afbeelding 1 van 3 Asus MeMO Pad 7 ME170C Power and Volume Button Replacement: stap 3, afbeelding 2 van 3 Asus MeMO Pad 7 ME170C Power and Volume Button Replacement: stap 3, afbeelding 3 van 3
    • Using a plastic opening tool, pry out the batteries to loosen them out.
    • The battery will be pried out of its port.
    • Lift the battery out of its port
  4. Asus MeMO Pad 7 ME170C Power and Volume Button Replacement, Power and Volume Button: stap 4, afbeelding 1 van 3 Asus MeMO Pad 7 ME170C Power and Volume Button Replacement, Power and Volume Button: stap 4, afbeelding 2 van 3 Asus MeMO Pad 7 ME170C Power and Volume Button Replacement, Power and Volume Button: stap 4, afbeelding 3 van 3
    • Locate the cable that connects the power button to the motherboard.
    • Carefully lift and release the connector lock that keeps it attached the motherboard. The connector lock rotates up away from the connection to release.
    • Carefully release the connection from the motherboard.
    • Gently pry the power and volume button away from the case. There should not be much resistance when prying the button off.
Conclusie
Thomas Brooks
301 Reputatie
3 handleidingen geschreven
IUPUI, Team S3-G3, Wilson Spring 2017 Lid van IUPUI, Team S3-G3, Wilson Spring 2017
IUPUI-WILSON-S17S3G3
5 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 611
