Ga door naar hoofdinhoud
Asus MeMO Pad 7 ME170C Microphone Replacement
Wat je nodig hebt
  1. Asus MeMO Pad 7 ME170C  Microphone  Replacement, Microphone: stap 1, afbeelding 1 van 3 Asus MeMO Pad 7 ME170C  Microphone  Replacement, Microphone: stap 1, afbeelding 2 van 3 Asus MeMO Pad 7 ME170C  Microphone  Replacement, Microphone: stap 1, afbeelding 3 van 3
    • Before beginning to dissemble, power off the device.
    • Excessive force can result in damaged or cracked screen. Be Gentle.
    • Using the Jimmy tool, gently wedge it into the seam of the device.
    • Gently pry the Jimmy tool all around the seam until the back panel is detached.
  2. Asus MeMO Pad 7 ME170C  Microphone  Replacement: stap 2, afbeelding 1 van 3 Asus MeMO Pad 7 ME170C  Microphone  Replacement: stap 2, afbeelding 2 van 3 Asus MeMO Pad 7 ME170C  Microphone  Replacement: stap 2, afbeelding 3 van 3
    • Inserted in a black port on the motherboard, locate the white cable connector on the left side of the tablet.
    • In a side to side motion, using the smallest opening tool, slide the white cable box completely out of the port towards the bottom of the device.
  3. Asus MeMO Pad 7 ME170C  Microphone  Replacement: stap 3, afbeelding 1 van 2 Asus MeMO Pad 7 ME170C  Microphone  Replacement: stap 3, afbeelding 2 van 2
    • Pull the wire out of its tracking panel gently.
    • Note: This wire should be fairly easy to pull out of the panel.
  4. Asus MeMO Pad 7 ME170C  Microphone  Replacement: stap 4, afbeelding 1 van 3 Asus MeMO Pad 7 ME170C  Microphone  Replacement: stap 4, afbeelding 2 van 3 Asus MeMO Pad 7 ME170C  Microphone  Replacement: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Note: The end of the wire is attached to a small taped black box.
    • Using wide nosed tweezers, lift up the tape and remove from black box.
    • Note: Black box will loosen up once the tape is removed.
    • Remove the component completely from the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,034
