Ga door naar hoofdinhoud
Asus MeMO Pad 7 ME170C Battery Replacement
Wat je nodig hebt
  1. Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Before beginning to disassemble, Power off the device.
    • Excessive force can result in damaged or cracked screen. Be Gentle.
    • Gently wedge a Jimmy into the seam of the device.
    • Gently pry the Jimmy all around the seam until the back panel is detached.
  2. Asus MeMO Pad 7 ME170C  Battery Replacement: stap 2, afbeelding 1 van 3 Asus MeMO Pad 7 ME170C  Battery Replacement: stap 2, afbeelding 2 van 3 Asus MeMO Pad 7 ME170C  Battery Replacement: stap 2, afbeelding 3 van 3
    • Locate the black bundle cable connector attached to the battery of the phone.
    • Do not push down. Slide in a forward motion to avoid breaking any inner pieces.
    • Using a plastic opening tool, gently slide the black bundle cable connector towards the battery in a back and forth motion until loosened and it slides out of connection port.
  3. Asus MeMO Pad 7 ME170C  Battery Replacement: stap 3, afbeelding 1 van 3 Asus MeMO Pad 7 ME170C  Battery Replacement: stap 3, afbeelding 2 van 3 Asus MeMO Pad 7 ME170C  Battery Replacement: stap 3, afbeelding 3 van 3
    • Using a plastic opening tool, pry out the batteries to loosen them out.
    • The battery will be pried out of its port.
    • Lift the battery out of its port
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 16
Altijd: 3,107
