Ga door naar hoofdinhoud
Asus K53E-MT1 Motherboard Replacement
Wat je nodig hebt
  1. Asus K53E-MT1 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Start by removing the battery and 2 Ph0 screws indicated here, then slide the cover to access hard drive, RAM modules and Wi-Fi card.
  2. Asus K53E-MT1 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the RAM module(s) by displacing both metal tabs outwards.
  3. Asus K53E-MT1 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • To extract the hard drive, remove 4 Ph00 screws indicated and pull the plastic tab to the left.
  4. Asus K53E-MT1 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Remove one Ph00 screw to pull the Wi-Fi card, then carefully disconnect both antenna cables, mind the black and white settings.
  5. Asus K53E-MT1 Motherboard Replacement: stap 5, afbeelding 1 van 2 Asus K53E-MT1 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Remove every screw you are able to see from the back cover, and keep them safe.
  6. Asus K53E-MT1 Motherboard Replacement: stap 6, afbeelding 1 van 2 Asus K53E-MT1 Motherboard Replacement: stap 6, afbeelding 2 van 2
    • You can safely remove all the screws from both sides of the battery, they won't let the display loose.
  7. Asus K53E-MT1 Motherboard Replacement: stap 7, afbeelding 1 van 3 Asus K53E-MT1 Motherboard Replacement: stap 7, afbeelding 2 van 3 Asus K53E-MT1 Motherboard Replacement: stap 7, afbeelding 3 van 3
    • Take a small flat screwdriver and displace the 5 tabs holding the keyboard one by one. Start on the right end and push the tabs in towards the screen as you lift the keyboard up.
    • Lift the keyboard being careful with the flex cable.
    • Release the keyboard ribbon from the motherboard by carefully sliding the black plastic part of the connector to the right.
  8. Asus K53E-MT1 Motherboard Replacement: stap 8, afbeelding 1 van 2 Asus K53E-MT1 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Remove every screw from this metal surface behind the keyboard.
    • You'll find the mousepad connector hidden by an isolating tape. Lift up the black part of the connector to remove the ribbon.
    • You'll also find the power button flex cable hidden by a tape. Lifting the black part of the connector will also allow you to remove this cable.
  9. Asus K53E-MT1 Motherboard Replacement: stap 9, afbeelding 1 van 2 Asus K53E-MT1 Motherboard Replacement: stap 9, afbeelding 2 van 2
    • At this point, you'll be able to remove the DVD tray by sticking a clip to the opening hole.
    • As shown in the photo, there are 3 ph00 screws you'll need to remove.
    • If you've done everything right, the top cover will now be completely free.
  10. Asus K53E-MT1 Motherboard Replacement: stap 10, afbeelding 1 van 3 Asus K53E-MT1 Motherboard Replacement: stap 10, afbeelding 2 van 3 Asus K53E-MT1 Motherboard Replacement: stap 10, afbeelding 3 van 3
    • Remove the microphone and earphone flex ribbon by lifting the black piece of the connector upwards.
    • To remove the display flex cable, there's a clear tape you'll have to clear away first (but do not disturb the yellow tape) then carefully displace the connector by pushing back against the two white lips of the cable to remove.
    • Disconnect the speaker connector in the same way.
  11. Asus K53E-MT1 Motherboard Replacement: stap 11, afbeelding 1 van 3 Asus K53E-MT1 Motherboard Replacement: stap 11, afbeelding 2 van 3 Asus K53E-MT1 Motherboard Replacement: stap 11, afbeelding 3 van 3
    • To remove the motherboard, take away those 5 screws indicated in the photos.
  12. Asus K53E-MT1 Motherboard Replacement: stap 12, afbeelding 1 van 1
    • At this point, the motherboard should be free to release.
    • And that's it for me. The display assembly is not shown here, sorry.
Conclusie
26 andere personen hebben deze handleiding voltooid.
Armando Rodriguez
640 Reputatie
1 Handleiding geschreven
7 opmerkingen
Awesome guide! my Asus K53E's power jack was damages and this guide made getting to the mother board to replace the part fairly east. In step 9 don't forget to check the entire back cover for screws before taking off the top cover, they arent all shown in the guide and there are a lot of them, if the case isnt coming away fairly easily you probably missed a screw so double check!
Greg Polinger - Antwoord
Ok. I'm glad it worked for you. In my case, I fixed a noise in the headphone's output, caused by the flex cable connecting to the motherboard.
Armando Rodriguez -
hIGH marks for this guide. $4 power jack, $100 labor. Now I know why, but it was so worth it.
thanks.
da11a8 - Antwoord
The power jack replacement I tried was useless because the solder was to difficult to remove and was nothing easy at all like tutorial videos on YouTube show! and I ended up breaking the Power jack area on the motherboard.
Shawn LH - Antwoord
Shawn LH; I got the exact same problem! The power jack is soldered with alot of silver I guess, cause it needed a very high temp. 450C was just enough, and the extreme small space did not help much.. I replaced the jack but the DC jack area on the motherboard had suffered alot of heat, so it did not connect anymore. Now ASUS can't support me and they refuse to send me a new motherboard.. have anyone tried bying boards on ebay?
Great guide BTW! Very detailed information ^^
Thomas -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 19
Altijd: 52,060
