Ga door naar hoofdinhoud
Asus K53E-BBR3 Keyboard Replacement
Wat je nodig hebt
  1. Asus K53E-BBR3 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 3 Asus K53E-BBR3 Keyboard Replacement, Battery: stap 1, afbeelding 2 van 3 Asus K53E-BBR3 Keyboard Replacement, Battery: stap 1, afbeelding 3 van 3
    • Place your laptop face down in front of you.
    • Slide the button in the top right corner to the right so that the orange marker is showing.
    • Press the spring loaded latch to release the battery from the computer.
  2. Asus K53E-BBR3 Keyboard Replacement, Keyboard: stap 2, afbeelding 1 van 3 Asus K53E-BBR3 Keyboard Replacement, Keyboard: stap 2, afbeelding 2 van 3 Asus K53E-BBR3 Keyboard Replacement, Keyboard: stap 2, afbeelding 3 van 3
    • There is a ribbon connector underneath the keyboard. When lifting up the keyboard be gentle and carefully it up.
    • Insert the spudger into the indent near the "ESC" key.
    • Firmly wiggle the spudger across the keyboard in between the space until you can remove the keyboard.
  3. Asus K53E-BBR3 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Gently pull the ribbon cable to the right and out of its port.
Conclusie
Liza Sousa
355 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 1-1, Catania Fall 2016 Lid van UMass Dartmouth, Team 1-1, Catania Fall 2016
UMASSD-CATANIA-F16S1G1
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 795
