Ga door naar hoofdinhoud
Inleiding
Replacing the hard drive on this device is quite easy as all of the components are accessible by removing a single cover.
  1. First, turn off your laptop, then disconnect the power supply. Unplug any peripheral devices connected to your laptop.
    • First, turn off your laptop, then disconnect the power supply. Unplug any peripheral devices connected to your laptop.
    • Next, remove the battery from the laptop.
    • In the picture, the battery is not installed.
  2. Next, remove the 4 Phillips screws from the service door cover (circled in red). In this photo, the screws have already been removed.
    • Next, remove the 4 Phillips screws from the service door cover (circled in red).
    • In this photo, the screws have already been removed.
  3. Remove the 4 screws circled in red in the photo. Once the screws are removed, slide the hard drive to the right, with the help of the tab.
    • Remove the 4 screws circled in red in the photo.
    • Once the screws are removed, slide the hard drive to the right, with the help of the tab.
  4. Remove the 4 screws located on the side of the support. Then, remove the hard drive form its metallic support. Finally, replace de hard drive with a new one or an SSD.
    • Remove the 4 screws located on the side of the support.
    • Then, remove the hard drive form its metallic support.
    • Finally, replace de hard drive with a new one or an SSD.
Conclusie
To reassemble your device, follow these steps in reverse order.
Met dank aan deze vertalers:
fr en
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
Brendan
20.352 Reputatie
1 Handleiding geschreven
why do you do this?
Carl Jefferson - Antwoord
You can do this to replace a faulty hard-drive or replace it by a SSD to get better performance. So I did this to replace mine by a new one and I wrote this guide for other people who search how to do it. As you can see, very easy to do.
Brendan -
Amazing tutorial, thanks :)
Jérémy Martin - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 836
