Ga door naar hoofdinhoud
Asus GL551JW-AH71 Wi-Fi Card Replacement
Wat je nodig hebt
  1. Asus GL551JW-AH71 Wi-Fi Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • Close the device and lay it upside down.
    • Unplug the device and make sure the device is powered off before removing the battery.
  2. Asus GL551JW-AH71 Wi-Fi Card Replacement: stap 2, afbeelding 1 van 2 Asus GL551JW-AH71 Wi-Fi Card Replacement: stap 2, afbeelding 2 van 2
    • Move the battery eject button to the right. The battery will be ejected.
  3. Asus GL551JW-AH71 Wi-Fi Card Replacement: stap 3, afbeelding 1 van 2 Asus GL551JW-AH71 Wi-Fi Card Replacement: stap 3, afbeelding 2 van 2
    • Grab the battery and remove it from the device.
  4. Asus GL551JW-AH71 Wi-Fi Card Replacement, Wi-Fi Card: stap 4, afbeelding 1 van 2 Asus GL551JW-AH71 Wi-Fi Card Replacement, Wi-Fi Card: stap 4, afbeelding 2 van 2
    • Using a Phillips #000 screwdriver, remove the two 16mm screws securing the access panel to the laptop.
  5. Asus GL551JW-AH71 Wi-Fi Card Replacement: stap 5, afbeelding 1 van 1
    • Gently remove the cover once the screws are removed.
  6. Asus GL551JW-AH71 Wi-Fi Card Replacement: stap 6, afbeelding 1 van 1
    • Locate the Wi-Fi card and detach both coaxial cables that are connected to the card.
    • The pictures in this step do not show a Wi-Fi card. The location where the Wi-Fi card would be located is indicated by the red rectangle.
  7. Asus GL551JW-AH71 Wi-Fi Card Replacement: stap 7, afbeelding 1 van 1
    • Grasp the Wi-Fi card gently and remove it carefully.
    • The pictures in this step do not show a Wi-Fi card, since it is missing from this particular device.
Conclusie
William Kelley
1.035 Reputatie
7 handleidingen geschreven
UMass Dartmouth, Team S8-G3, Bailey Spring 2019 Lid van UMass Dartmouth, Team S8-G3, Bailey Spring 2019
UMASSD-BAILEY-S19S8G3
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 18
Altijd: 910
