Ga door naar hoofdinhoud
Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement
Wat je nodig hebt
  1. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement, Battery: stap 1, afbeelding 1 van 1
    • Power off and unplug your laptop, then turn it over.
  2. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: stap 2, afbeelding 1 van 1
    • Slide the battery release latch all the way to the right. This will cause the battery to "pop" out slightly.
  3. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery from its compartment.
  4. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement, Left and Right Speaker Bar: stap 4, afbeelding 1 van 2 Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement, Left and Right Speaker Bar: stap 4, afbeelding 2 van 2
    • Remove the rubber stoppers in the top left and right corners to expose two 9mm Phillips #00 screws. Unscrew and remove them.
    • Unscrew and remove the three 4mm Phillips #00 screws inside the battery compartment.
  5. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: stap 5, afbeelding 1 van 1
    • Carefully turn the laptop right-side up.
    • Using an opening tool, pry the outer edges of the hinge cover up and away from the laptop.
    • The hinge cover, located at the back of the laptop, is the long plastic plate that covers the hinges and speakers.
  6. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: stap 6, afbeelding 1 van 3 Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: stap 6, afbeelding 2 van 3 Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: stap 6, afbeelding 3 van 3
    • Without disconnecting the speaker cable, set the hinge cover upside-down.
    • Hold the speaker cable by its white connector, then pull to unplug it from the motherboard.
    • You may need to apply some force, as these connectors can be difficult to unplug.
  7. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: stap 7, afbeelding 1 van 1
    • The speaker is attached to the hinge cover by four 3.5mm Phillips #00 screws. Unscrew and remove them.
  8. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: stap 8, afbeelding 1 van 1
    • Lift the speaker to remove it.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Stephanie Asling
424 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 732
