Ga door naar hoofdinhoud
Asus G750JW-BBI7N05 Hard Drive Replacement
Wat je nodig hebt
  1. Asus G750JW-BBI7N05 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Power off and unplug your laptop, then turn it over.
  2. Asus G750JW-BBI7N05 Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Slide the battery release latch all the way to the right. This will cause the battery to "pop" out slightly.
  3. Asus G750JW-BBI7N05 Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery from its compartment.
  4. Asus G750JW-BBI7N05 Hard Drive Replacement, Hard Drive: stap 4, afbeelding 1 van 2 Asus G750JW-BBI7N05 Hard Drive Replacement, Hard Drive: stap 4, afbeelding 2 van 2
    • Lift up the rubber stopper on the backplate to expose one Phillips #00 screw. Unscrew it until it becomes loose.
    • This screw is permanently connected to the backplate and cannot be removed. Unscrewing it only allows you to remove the lower case from the laptop.
    • The backpate is the plastic plate on the underside of the laptop that covers some of its easily accessible internal components.
  5. Asus G750JW-BBI7N05 Hard Drive Replacement: stap 5, afbeelding 1 van 1
    • Use an opening tool to pry up the backplate along its edges, then remove it.
    • You may need to apply some force when prying up the backplate.
    • Keep in mind: During reassembly, replace the backplate starting from the bottom.
  6. Asus G750JW-BBI7N05 Hard Drive Replacement: stap 6, afbeelding 1 van 2 Asus G750JW-BBI7N05 Hard Drive Replacement: stap 6, afbeelding 2 van 2
    • On the left metal hard drive casing, unscrew and remove the indicated three 4mm Phillips #00 screws.
    • The right hard drive casing is for optional secondary hard drives.
  7. Asus G750JW-BBI7N05 Hard Drive Replacement: stap 7, afbeelding 1 van 2 Asus G750JW-BBI7N05 Hard Drive Replacement: stap 7, afbeelding 2 van 2
    • Use the black tab as leverage to slide the metal hard drive casing all the way to the left.
    • Still holding the black tab, pull the hard drive casing up to remove it from the laptop.
  8. Asus G750JW-BBI7N05 Hard Drive Replacement: stap 8, afbeelding 1 van 1
    • Unscrew and remove the four 4mm Phillips #00 screws around the metal casing. Each side has two screws.
    • Slide the hard drive out of its metal casing.
Conclusie
Siyuan Yan
131 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 19
Altijd: 2,270
