Ga door naar hoofdinhoud
Asus G74SX-BBK7 Trackpad Button Replacement
Wat je nodig hebt
  1. Asus G74SX-BBK7 Trackpad Button Replacement, Optical Drive: stap 1, afbeelding 1 van 1
    • Using a flathead screwdriver, spudger, or large coin such as a quarter, remove the 13mm screw on the bottom of the laptop.
    • Take off the back panel.
  2. Asus G74SX-BBK7 Trackpad Button Replacement: stap 2, afbeelding 1 van 1
    • Now, unscrew and remove the 6mm Phillips #0 screw next to the optical drive.
  3. Asus G74SX-BBK7 Trackpad Button Replacement: stap 3, afbeelding 1 van 2 Asus G74SX-BBK7 Trackpad Button Replacement: stap 3, afbeelding 2 van 2
    • Lastly, use a plastic opening tool to remove the optical drive from its slot.
  4. Asus G74SX-BBK7 Trackpad Button Replacement, Trackpad Button: stap 4, afbeelding 1 van 1
    • Remove the two 6mm Phillips #0 screws that were previously covered by the optical drive using a Phillips #0 screwdriver.
  5. Asus G74SX-BBK7 Trackpad Button Replacement: stap 5, afbeelding 1 van 1
    • First, remove the five 10mm Phillips #0 screws from the back of the computer near the top.
    • Remove all eighteen 6mm Phillips #0 screws from the bottom of the computer.
    • Some of the screws are set very deeply in the back case - you will need a long and narrow screwdriver to remove them.
  6. Asus G74SX-BBK7 Trackpad Button Replacement: stap 6, afbeelding 1 van 2 Asus G74SX-BBK7 Trackpad Button Replacement: stap 6, afbeelding 2 van 2
    • Next, pry open back plastic cover using a metal spudger.
    • Unscrew the four 10mm Phillips #0 screws under the cover.
  7. Asus G74SX-BBK7 Trackpad Button Replacement: stap 7, afbeelding 1 van 3 Asus G74SX-BBK7 Trackpad Button Replacement: stap 7, afbeelding 2 van 3 Asus G74SX-BBK7 Trackpad Button Replacement: stap 7, afbeelding 3 van 3
    • Lay laptop opened and completely flat.
    • Using the metal spudger, slowly pry open the front main panel by going around each side.
    • Lift the top panel out, pulling the cable strips out of their sockets. These will be reattached later.
    • Be careful when lifting the top panel. There are cable strips attached to the motherboard that need to be removed.
  8. Asus G74SX-BBK7 Trackpad Button Replacement: stap 8, afbeelding 1 van 2 Asus G74SX-BBK7 Trackpad Button Replacement: stap 8, afbeelding 2 van 2
    • After separating the main panel and the motherboard, unscrew two 6mm Phillips #0 screws.
    • Remove the mouse button.
  9. Asus G74SX-BBK7 Trackpad Button Replacement: stap 9, afbeelding 1 van 3 Asus G74SX-BBK7 Trackpad Button Replacement: stap 9, afbeelding 2 van 3 Asus G74SX-BBK7 Trackpad Button Replacement: stap 9, afbeelding 3 van 3
    • To reconnect the motherboard and main panel, insert strips back to their corresponding location.
    • To do this, first remove the tape and open up the tab. Plug in the strip and and close the tab.
    • It may be helpful to have someone help you hold the main panel while you reconnect the strips.
Conclusie
Ryan Lawrence
611 Reputatie
5 handleidingen geschreven
Cal Poly, Team 5-10, Maness Spring 2015 Lid van Cal Poly, Team 5-10, Maness Spring 2015
CPSU-MANESS-S15S5G10
4 Leden
6 handleidingen geschreven
Één opmerking
Where did you find the part?
websmiths - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 12
Altijd: 4,782
