Wat je nodig hebt
Make sure the computer is off and turn it over on its back. Push the slider all the way back until the compartment for the battery opens. Remove the battery and place it aside.
Find the panel on the back of the computer. Use a Phillips #0 screwdriver to unscrew the 2 4.2mm screws on that panel. Next, lift up the panel at the indent and place it aside.
Placing your hand on the side of the disk drive closest to the motherboard, slightly push down and out to remove the drive.
In this step, remove the nine 4.2 mm screws that hold the motherboard to the laptop itself using the Phillips #0 screwdriver.
Take the motherboard gently from the laptop.
5 opmerkingen
(part 1) My advice to anyone who is tearing one of these down, take a picture of each step with your cell phone as if you are making a guide for yourself. Use a mat with a screw organizer, or some method of organizing screws, and organize them by each group. Don’t be afraid to take notes on the laptop using masking tape and a fine point sharpie. Take your time, if something won’t budge, remove more screws. (for example) On the left hinge, before you can remove the LCD assembly, you need to remove a small board that is hiding two screws underneath.
(part 2) If you take your time, and take a lot of pictures, and take notes, you’ll get ‘er done :) Follow your own guide backwards for reassembly. The “I fix it” guide at the top is really just a vague overview, lacking so many steps. It’s kinda helpful, but also kind of a joke. Tearing down this laptop may take as much as one hour your first time. When I tore mine down, the thermal paste was 8 years old and needed to be replaced. There was a warranty sticker on one screw for the heatsink / fan assembly, indicating that this 2012 laptop had probably never been torn down. OK, it’s Q4 2020 and I’m going to fix this 2012 gaming laptop, LOL. Will it play Fallout 4 ? w00t :)
Scroll down on this forum thread, there are pics of a complete teardown : https://rog.asus.com/forum/showthread.ph...
