Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Flip laptop face down and rotate so the battery is facing toward you.
To remove the battery, place one finger on each of the two black slide tabs. Push each tab toward the center of the laptop to release the lock.
Slide the battery toward you and lift it out of the laptop.
With the laptop facing down, rotate it so the battery pack is facing away from you.
Remove the six 1.5 mm Phillips #1 screws on the back panel of the laptop.
Insert a finger into one of the slots on the bottom panel.
Gently lift the upwards, and the back panel of the laptop will come off easily.
Rotate the laptop 90 degrees towards you so that you are looking at the empty battery compartment.
Remove the 2.0 mm Phillips #3 screw located beneath the battery compartment.
Lay the laptop flat on its back.
Gently pull left on the black tab, located on the left side of the hard drive, until it pops out.
Slowly lift the tab up and pull the hard drive out of the laptop.
Één andere persoon heeft deze handleiding voltooid.
