Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Flip laptop face down and rotate so the battery is facing toward you.
To remove the battery, place one finger on each of the two black slide tabs. Push each tab toward the center of the laptop to release the lock.
Slide the battery toward you and lift it out of the laptop.
With the laptop facing down, rotate it so the battery pack is facing away from you.
Remove the six 1.5 mm Phillips #1 screws on the back panel of the laptop.
Insert a finger into one of the slots on the bottom panel.
Gently lift the upwards, and the back panel of the laptop will come off easily.
Remove the three 2.0mm Phillips #1 screws that secure the metal guard.
With the screws removed, simply lift the metal guard out of the laptop to remove it.
Disconnect the fan from the motherboard by pulling the black cord straight up.
Remove the 1.5mm Phillips #1 screws attaching the fan to the motherboard.
Using the flat end of a spudger, gently pry upwards on the adhesive attaching the fan to the side of the laptop.
Remove the four 1.25 mm Phillips #1 screw that secure the heat sink in place.
With one hand holding the heat sink, and the other hand holding the fan, pull upwards with moderate force to remove the compents from the laptop.
Flip the fan and heat sink over so the metal end of the fan is facing upwards, and lay it flat.
Using the flat end of a spudger, gently pry off the adhesive attaching the fan to the plastic.
With the adhesive off, simply pull the fan away from the plastic to remove it.
