Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
The access panel is a metal and plastic piece that encapsulates and protects the inner mechanical parts of a laptop. Be sure to have a compatible back panel for this laptop when replacing it.
Wat je nodig hebt
With the laptop facing down, rotate it so the battery pack is facing away from you.
Remove the six 1.5 mm Phillips #1 screws on the back panel of the laptop.
