Inleiding
This guide will show you how to remove and replace the CPU fan on your ASUS F555-AB31 laptop. The fan is located behind the Motherboard so nearly full disassembly of the device is required to access it.
Wat je nodig hebt
Fold the faceplate upwards towards the screen to fully expose the inside of the laptop.
Both the battery and the hard drive adapter PCB will need to be moved in order to lift and access the backside of the motherboard.
Unscrew the eight Phillips #0 screws on from the battery, and four Phillips #0 screws from the hard drive adapter PCB.
Remove the seven 4mm Phillips #0 screws holding the motherboard down to the laptop chassis.
Lift the motherboard upwards, folding it towards the laptop screen.
Disconnect the 4-pin PWM cable attaching the fan to the back of the motherboard. The fan can now be removed by simply sliding the fan off the copper heat pipe.
Één andere persoon heeft deze handleiding voltooid.
