Ga door naar hoofdinhoud
Asus F555LA-AB31 Fan Replacement
Wat je nodig hebt
  1. Asus F555LA-AB31 Fan Replacement, Fan: stap 1, afbeelding 1 van 1
    • Remove ten 18mm Phillips #0 screws from the backside of the device.
    • Removal of the RAM access panel is not necessary.
  2. Asus F555LA-AB31 Fan Replacement: stap 2, afbeelding 1 van 3 Asus F555LA-AB31 Fan Replacement: stap 2, afbeelding 2 van 3 Asus F555LA-AB31 Fan Replacement: stap 2, afbeelding 3 van 3
    • Open the laptop.
    • Begin to pry upward on the edges of the faceplate in order to separate the keyboard and trackpad from the rest of the device.
    • Be cautious of the cables connecting the keyboard and trackpad to the motherboard.
    • To remove the ZIF connector, gently lift upward on the blue tab to disconnect it from the motherboard.
  3. Asus F555LA-AB31 Fan Replacement: stap 3, afbeelding 1 van 1
    • Fold the faceplate upwards towards the screen to fully expose the inside of the laptop.
    • Both the battery and the hard drive adapter PCB will need to be moved in order to lift and access the backside of the motherboard.
    • Unscrew the eight Phillips #0 screws on from the battery, and four Phillips #0 screws from the hard drive adapter PCB.
  4. Asus F555LA-AB31 Fan Replacement: stap 4, afbeelding 1 van 3 Asus F555LA-AB31 Fan Replacement: stap 4, afbeelding 2 van 3 Asus F555LA-AB31 Fan Replacement: stap 4, afbeelding 3 van 3
    • Remove the CD drive by unscrewing the single 4mm Phillips #0 screw and sliding the drive away from the motherboard.
    • Disconnect the two antennas that are attached to the network card.
  5. Asus F555LA-AB31 Fan Replacement: stap 5, afbeelding 1 van 2 Asus F555LA-AB31 Fan Replacement: stap 5, afbeelding 2 van 2
    • Remove the seven 4mm Phillips #0 screws holding the motherboard down to the laptop chassis.
    • Lift the motherboard upwards, folding it towards the laptop screen.
    • The motherboard will still be attached by two wires, but it is unnecessary to remove these wires to access the fan.
    • Disconnect the 4-pin PWM cable attaching the fan to the back of the motherboard. The fan can now be removed by simply sliding the fan off the copper heat pipe.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 955
