Ga door naar hoofdinhoud
Asus F554LA-WS52 Keyboard Replacement
Wat je nodig hebt
  1. Asus F554LA-WS52 Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 2 Asus F554LA-WS52 Keyboard Replacement, Keyboard: stap 1, afbeelding 2 van 2
    • Make sure the notebook is off and has been unplugged from any power source.
    • Flip the notebook over and remove the 10 screws from the back plate with a #0 Phillips head screwdriver.
    • Six (6) will be 9.6mm and four (4) will be 12.7mm.
  2. Asus F554LA-WS52 Keyboard Replacement: stap 2, afbeelding 1 van 3 Asus F554LA-WS52 Keyboard Replacement: stap 2, afbeelding 2 van 3 Asus F554LA-WS52 Keyboard Replacement: stap 2, afbeelding 3 van 3
    • Flip the notebook back over.
    • Gently lift and remove the keyboard with a plastic opening tool.
  3. Asus F554LA-WS52 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • (Not pictured) Remove the three cables attached to the keyboard and one from the touch-pad.
    • (Not pictured) With the plastic opening tool, pry off the metal separation plate from the keyboard.
    • (Not pictured) With the plastic opening tool, gently pry the keyboard from its position and replace.
Conclusie
Aaron Ratliff
527 Reputatie
4 handleidingen geschreven
USF Tampa, Team S1-G2, Leahy Fall 2018 Lid van USF Tampa, Team S1-G2, Leahy Fall 2018
USFT-LEAHY-F18S1G2
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 308
