Ga door naar hoofdinhoud
Asus F554LA-WS52 Disc Drive
Wat je nodig hebt
  1. Asus F554LA-WS52 Disc Drive, Disc Drive: stap 1, afbeelding 1 van 2 Asus F554LA-WS52 Disc Drive, Disc Drive: stap 1, afbeelding 2 van 2
    • Make sure the notebook is off and has been unplugged from any power source.
    • Flip the notebook over and remove the 10 screws from the back plate with a #0 Phillips head screwdriver.
    • Six (6) will be 9.6mm and four (4) will be 12.7mm.
  2. Asus F554LA-WS52 Disc Drive: stap 2, afbeelding 1 van 3 Asus F554LA-WS52 Disc Drive: stap 2, afbeelding 2 van 3 Asus F554LA-WS52 Disc Drive: stap 2, afbeelding 3 van 3
    • With a plastic opening tool, gently lift and remove the back cover to expose the internal components.
    • (Not pictured) Remove the three cables attached to the keyboard and one touch-pad.
  3. Asus F554LA-WS52 Disc Drive: stap 3, afbeelding 1 van 2 Asus F554LA-WS52 Disc Drive: stap 3, afbeelding 2 van 2
    • Unscrew the three 5.7 mm hard drive-motherboard connection screws with a #0 Phillips head screwdriver.
    • Remove the small rectangular hard drive-motherboard connection board.
    • (Not pictured) Remove the hard drive.
  4. Asus F554LA-WS52 Disc Drive: stap 4, afbeelding 1 van 2 Asus F554LA-WS52 Disc Drive: stap 4, afbeelding 2 van 2
    • Unscrew the four 5.7 mm battery screws with a #0 Phillips head screwdriver.
    • Remove the battery.
  5. Asus F554LA-WS52 Disc Drive: stap 5, afbeelding 1 van 3 Asus F554LA-WS52 Disc Drive: stap 5, afbeelding 2 van 3 Asus F554LA-WS52 Disc Drive: stap 5, afbeelding 3 van 3
    • Unscrew the two 2.7 mm and one 5.7 mm CD drive screws with the Phillips #00 screwdriver.
    • With the plastic opening tool, gently pry the drive out from the metal brackets that hold it in place.
Conclusie
Aaron Ratliff
527 Reputatie
4 handleidingen geschreven
USF Tampa, Team S1-G2, Leahy Fall 2018 Lid van USF Tampa, Team S1-G2, Leahy Fall 2018
USFT-LEAHY-F18S1G2
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 550
