Ga door naar hoofdinhoud
Asus EeeBook X205TA Speakers Replacement
Wat je nodig hebt
  1. Asus EeeBook X205TA Speakers Replacement, Battery: stap 1, afbeelding 1 van 2 Asus EeeBook X205TA Speakers Replacement, Battery: stap 1, afbeelding 2 van 2
    • Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
  2. Asus EeeBook X205TA Speakers Replacement: stap 2, afbeelding 1 van 1
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Speakers Replacement: stap 3, afbeelding 1 van 2 Asus EeeBook X205TA Speakers Replacement: stap 3, afbeelding 2 van 2
    • Unscrew all six 2mm screws using Philips #2 screws along the edges of the L-Shaped battery.
    • Any tape or cords that run along the battery should be carefully pushed to the side.
  4. Asus EeeBook X205TA Speakers Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the battery from the motherboard by pulling the No-Fuss Ribbon cables out of the connector.
  5. Asus EeeBook X205TA Speakers Replacement: stap 5, afbeelding 1 van 1
    • Carefully lift the battery out of the laptop.
  6. Asus EeeBook X205TA Speakers Replacement, Speakers: stap 6, afbeelding 1 van 1
    • Locate and lift the tabs from the LED/motherboard ribbon cable.
    • Remove the cable.
  7. Asus EeeBook X205TA Speakers Replacement: stap 7, afbeelding 1 van 1
    • Unplug the speaker cable from the motherboard.
  8. Asus EeeBook X205TA Speakers Replacement: stap 8, afbeelding 1 van 1
    • Pry the right speaker gently with the plastic opening tool.
  9. Asus EeeBook X205TA Speakers Replacement: stap 9, afbeelding 1 van 1
    • Pry the left speaker gently with the plastic opening tool.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
William Riggins
312 Reputatie
2 handleidingen geschreven
IUPUI, Team S3-G4, Baechle Spring 2017 Lid van IUPUI, Team S3-G4, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G4
4 Leden
6 handleidingen geschreven
2 opmerkingen
Thank you very much for this detailed and helpful tutorial.
andrew - Antwoord
Thanks. You’ve helped make it clearer for me!
geometry dash
Martin Tolley - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 893
