Inleiding
In this guide you will learn how to replace the speakers in an Asus EeeBook X205TA.
Wat je nodig hebt
Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
Locate and lift the tabs from the LED/motherboard ribbon cable.
Remove the cable.
Één andere persoon heeft deze handleiding voltooid.
2 opmerkingen
Thanks. You’ve helped make it clearer for me!
