Ga door naar hoofdinhoud
Asus EeeBook X205TA LED Screen Panel Chip Replacement
Wat je nodig hebt
  1. Asus EeeBook X205TA LED Screen Panel Chip Replacement, Battery: stap 1, afbeelding 1 van 2 Asus EeeBook X205TA LED Screen Panel Chip Replacement, Battery: stap 1, afbeelding 2 van 2
    • Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
  2. Asus EeeBook X205TA LED Screen Panel Chip Replacement: stap 2, afbeelding 1 van 1
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA LED Screen Panel Chip Replacement: stap 3, afbeelding 1 van 2 Asus EeeBook X205TA LED Screen Panel Chip Replacement: stap 3, afbeelding 2 van 2
    • Unscrew all six 2mm screws using Philips #2 screws along the edges of the L-Shaped battery.
    • Any tape or cords that run along the battery should be carefully pushed to the side.
  4. Asus EeeBook X205TA LED Screen Panel Chip Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the battery from the motherboard by pulling the No-Fuss Ribbon cables out of the connector.
  5. Asus EeeBook X205TA LED Screen Panel Chip Replacement: stap 5, afbeelding 1 van 1
    • Carefully lift the battery out of the laptop.
  6. Asus EeeBook X205TA LED Screen Panel Chip Replacement, LED Screen Panel Chip: stap 6, afbeelding 1 van 1
    • Locate and lift the tabs from the LED/motherboard ribbon cable.
    • Remove the cable.
  7. Asus EeeBook X205TA LED Screen Panel Chip Replacement: stap 7, afbeelding 1 van 1
    • Unscrew the 1 JIS 2mm screw with the J0 bit.
  8. Asus EeeBook X205TA LED Screen Panel Chip Replacement: stap 8, afbeelding 1 van 1
    • Remove the chip.
Conclusie
Rachael
125 Reputatie
1 Handleiding geschreven
IUPUI, Team S3-G4, Baechle Spring 2017 Lid van IUPUI, Team S3-G4, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G4
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 20
Altijd: 1,165
