Ga door naar hoofdinhoud
Asus EeeBook X205TA Battery Replacement
Wat je nodig hebt
  1. Asus EeeBook X205TA Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Asus EeeBook X205TA Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
  2. Asus EeeBook X205TA Battery Replacement: stap 2, afbeelding 1 van 1
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Battery Replacement: stap 3, afbeelding 1 van 2 Asus EeeBook X205TA Battery Replacement: stap 3, afbeelding 2 van 2
    • Unscrew all six 2mm screws using Philips #2 screws along the edges of the L-Shaped battery.
    • Any tape or cords that run along the battery should be carefully pushed to the side.
  4. Asus EeeBook X205TA Battery Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the battery from the motherboard by pulling the No-Fuss Ribbon cables out of the connector.
  5. Asus EeeBook X205TA Battery Replacement: stap 5, afbeelding 1 van 1
    • Carefully lift the battery out of the laptop.
Conclusie
Follow the guide in reverse order to reassemble the device.
8 andere personen hebben deze handleiding voltooid.
Lorena Santiago
712 Reputatie
4 handleidingen geschreven
USF Tampa, Team 2-2, Sullivan Fall 2016 Lid van USF Tampa, Team 2-2, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G2
3 Leden
10 handleidingen geschreven
11 opmerkingen
By any chance , Can we run this laptop without battery ? I mean directly from AC ? Please suggest
Sourabh Verma - Antwoord
No, you must have the battery on.
Tayler Grant -
is this under warenty
bla bla - Antwoord
If you have one….
Tayler Grant -
My battery is stuck on orange led mode. My laptop cannot identify the battery….
Tayler Grant - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 74
Altijd: 13,851
