Ga door naar hoofdinhoud
Asus EeeBook X205TA USB Port Replacement
Wat je nodig hebt
  1. Asus EeeBook X205TA  USB Port Replacement, USB Port: stap 1, afbeelding 1 van 2 Asus EeeBook X205TA  USB Port Replacement, USB Port: stap 1, afbeelding 2 van 2
    • Unscrew all 10 screws located on the bottom of the laptop using a Phillips #2 Screwdriver.
    • Keep in mind that some of the screws vary in length, so keep track of which screws were placed in each hole.
  2. Asus EeeBook X205TA  USB Port Replacement: stap 2, afbeelding 1 van 1
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA  USB Port Replacement: stap 3, afbeelding 1 van 2 Asus EeeBook X205TA  USB Port Replacement: stap 3, afbeelding 2 van 2
    • The USB ports are located on the strip that looks like the motherboard on the left side of the laptop next to the battery.
    • Unscrew the four screws using Philips #2 screwdriver located around the edge of the USB ports.
    • Unplug the battery ZIF connector from the USB ports.
  4. Asus EeeBook X205TA  USB Port Replacement: stap 4, afbeelding 1 van 1
    • Carefully remove the USB ports from the laptop.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Lorena Santiago
736 Reputatie
4 handleidingen geschreven
USF Tampa, Team 2-2, Sullivan Fall 2016 Lid van USF Tampa, Team 2-2, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G2
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 28
Altijd: 2,785
