Ga door naar hoofdinhoud
Asus Eee PC 900 Touchpad Replacement
Wat je nodig hebt
  1. Asus Eee PC 900 Touchpad Replacement, Battery: stap 1, afbeelding 1 van 3 Asus Eee PC 900 Touchpad Replacement, Battery: stap 1, afbeelding 2 van 3 Asus Eee PC 900 Touchpad Replacement, Battery: stap 1, afbeelding 3 van 3
    • Slide the battery's locking tabs from the locked position to unlocked positions.
    • The right tab is unlocked when a red dot is showing.
    • The left tab will have to be held in the unlocked position in order to release the battery.
  2. Asus Eee PC 900 Touchpad Replacement: stap 2, afbeelding 1 van 1
    • Slide the battery out while holding the left locking tab in the unlocked position.
  3. Asus Eee PC 900 Touchpad Replacement, Keyboard: stap 3, afbeelding 1 van 2 Asus Eee PC 900 Touchpad Replacement, Keyboard: stap 3, afbeelding 2 van 2
    • Caution Follow this step to detach the upper portion of the keyboard, but do not remove it from the laptop. Damage to the keyboard's ribbon cable may result if improperly executed.
    • Identify the three metal tabs holding down the laptop's keyboard.
    • Using a spudger, depress each metal tab to remove the keyboard.
    • The upper part of the keyboard should "pop up" from its holder.
  4. Asus Eee PC 900 Touchpad Replacement: stap 4, afbeelding 1 van 2 Asus Eee PC 900 Touchpad Replacement: stap 4, afbeelding 2 van 2
    • Clips hold the bottom portion of the keyboard to the laptop. Gently lift the upper portion of the keyboard and then move the entire keyboard towards the computer's screen until the ribbon cable is visible.
  5. Asus Eee PC 900 Touchpad Replacement: stap 5, afbeelding 1 van 1
    • Using a spudger, gently push the two black pins holding the ribbon cable towards the computer's screen.
    • Slide the keyboard's ribbon cable from the connector.
  6. Asus Eee PC 900 Touchpad Replacement: stap 6, afbeelding 1 van 1
    • Remove the keyboard by lifting upwards.
  7. Asus Eee PC 900 Touchpad Replacement, Top Cover: stap 7, afbeelding 1 van 2 Asus Eee PC 900 Touchpad Replacement, Top Cover: stap 7, afbeelding 2 van 2
    • Remove the nine 4.76mm Phillips #0 screws on the top cover of the laptop.
  8. Asus Eee PC 900 Touchpad Replacement: stap 8, afbeelding 1 van 2 Asus Eee PC 900 Touchpad Replacement: stap 8, afbeelding 2 van 2
    • Remove the six 4.76 mm Phillips #0 screws on the back of the laptop.
  9. Asus Eee PC 900 Touchpad Replacement: stap 9, afbeelding 1 van 3 Asus Eee PC 900 Touchpad Replacement: stap 9, afbeelding 2 van 3 Asus Eee PC 900 Touchpad Replacement: stap 9, afbeelding 3 van 3
    • Flip the laptop back over and identify the touchpad ribbon.
    • Unlock the tan locking pin from the black connector by pushing the pin to the right with a spudger.
  10. Asus Eee PC 900 Touchpad Replacement: stap 10, afbeelding 1 van 1
    • Slide out the touchpad's ribbon connector by pulling the blue tab to the right.
  11. Asus Eee PC 900 Touchpad Replacement: stap 11, afbeelding 1 van 1
    • Use a plastic opening tool to gently detach the top cover from the laptop's base. See the next step for removing the cover.
  12. Asus Eee PC 900 Touchpad Replacement: stap 12, afbeelding 1 van 3 Asus Eee PC 900 Touchpad Replacement: stap 12, afbeelding 2 van 3 Asus Eee PC 900 Touchpad Replacement: stap 12, afbeelding 3 van 3
    • Caution: To clear the audio and microphone, lift the right half and move the cover to the left (as shown in the second picture) to prevent cover damage.
    • Remove the laptop cover.
  13. Asus Eee PC 900 Touchpad Replacement, Touchpad: stap 13, afbeelding 1 van 2 Asus Eee PC 900 Touchpad Replacement, Touchpad: stap 13, afbeelding 2 van 2
    • Flip the top cover over and identify the touchpad back plate.
  14. Asus Eee PC 900 Touchpad Replacement: stap 14, afbeelding 1 van 3 Asus Eee PC 900 Touchpad Replacement: stap 14, afbeelding 2 van 3 Asus Eee PC 900 Touchpad Replacement: stap 14, afbeelding 3 van 3
    • Identify the conductive foil.
    • Caution: Do not completely remove conductive foil.
    • Fold back the conductive foil from the touchpad back plate using a spudger.
  15. Asus Eee PC 900 Touchpad Replacement: stap 15, afbeelding 1 van 2 Asus Eee PC 900 Touchpad Replacement: stap 15, afbeelding 2 van 2
    • Remove the two 4.76mm Phillips #0 screws securing the touchpad back plate.
  16. Asus Eee PC 900 Touchpad Replacement: stap 16, afbeelding 1 van 1
    • Remove the yellow tape holding the touchpad's ribbon connector with a spudger.
  17. Asus Eee PC 900 Touchpad Replacement: stap 17, afbeelding 1 van 3 Asus Eee PC 900 Touchpad Replacement: stap 17, afbeelding 2 van 3 Asus Eee PC 900 Touchpad Replacement: stap 17, afbeelding 3 van 3
    • Use a spudger to lift the front edge of the touchpad back plate.
    • Gently grasp the edges of the back plate and pull towards you to remove.
  18. Asus Eee PC 900 Touchpad Replacement: stap 18, afbeelding 1 van 1
    • Lift the touchpad out of its placeholder.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Sheldon Chu
1.099 Reputatie
3 handleidingen geschreven
Cal Poly, Team 3-27, Amido Winter 2012 Lid van Cal Poly, Team 3-27, Amido Winter 2012
CPSU-AMIDO-W12S3G27
4 Leden
16 handleidingen geschreven
2 opmerkingen
Where is STEP 2 1/2? my keyboard dosnt just fall out nice, how do you remove the keyboard?
Support Services - Antwoord
Yeah I don't know how to remove keyboard. Also once I get to step 14.. What do I do? You tell me how to identify the broken piece but is it replaceable or fixable?
el jay - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 25
Altijd: 10,090
