Ga door naar hoofdinhoud
Asus Eee PC 900 RAM Replacement
Wat je nodig hebt
  1. Asus Eee PC 900 RAM Replacement, Battery: stap 1, afbeelding 1 van 3 Asus Eee PC 900 RAM Replacement, Battery: stap 1, afbeelding 2 van 3 Asus Eee PC 900 RAM Replacement, Battery: stap 1, afbeelding 3 van 3
    • Slide the battery's locking tabs from the locked position to unlocked positions.
    • The right tab is unlocked when a red dot is showing.
    • The left tab will have to be held in the unlocked position in order to release the battery.
  2. Asus Eee PC 900 RAM Replacement: stap 2, afbeelding 1 van 1
    • Slide the battery out while holding the left locking tab in the unlocked position.
  3. Asus Eee PC 900 RAM Replacement, RAM: stap 3, afbeelding 1 van 2 Asus Eee PC 900 RAM Replacement, RAM: stap 3, afbeelding 2 van 2
    • Remove the sticker from the RAM compartment using a pair of tweezers.
  4. Asus Eee PC 900 RAM Replacement: stap 4, afbeelding 1 van 2 Asus Eee PC 900 RAM Replacement: stap 4, afbeelding 2 van 2
    • Remove the two 4.8 mm screws using a Phillips #0 screwdriver.
  5. Asus Eee PC 900 RAM Replacement: stap 5, afbeelding 1 van 1
    • Open up the cover from the bottom by carefully prying it open with a plastic opening tool.
    • Be gentle when prying open the cover in order to not damage it.
  6. Asus Eee PC 900 RAM Replacement: stap 6, afbeelding 1 van 1
    • Remove the back cover by pulling up on the side that had the screws.
  7. Asus Eee PC 900 RAM Replacement: stap 7, afbeelding 1 van 2 Asus Eee PC 900 RAM Replacement: stap 7, afbeelding 2 van 2
    • Use a spudger to push the top of the pin on the right towards the right (so it isn't holding the RAM chip).
    • Do the same for the left pin. Push the top of the pin towards the left.
    • The RAM should pop up.
  8. Asus Eee PC 900 RAM Replacement: stap 8, afbeelding 1 van 1
    • Remove the RAM chip by grabbing the top of the chip and pulling it upwards.
    • Be gentle when removing the RAM because it is a very delicate part and you do not want to break any of the pins in the computer.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Brian Carreon
288 Reputatie
2 handleidingen geschreven
Cal Poly, Team 3-27, Amido Winter 2012 Lid van Cal Poly, Team 3-27, Amido Winter 2012
CPSU-AMIDO-W12S3G27
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 32
Altijd: 8,791
